[GRASS-dev] no grass plugin in qgis installed from osgeo4w
Pedro Venâncio
pedrongvenancio at gmail.com
Tue Oct 27 07:53:38 PDT 2015
Hi Veronica,
Did you install GRASS in OSGeo4W? Which version?
On Sunday I made an installation on Windows and I found a problem. GRASS
7.0.2RC is already available on OSGeo4W. However, the .bat file that is
created for the use of GRASS7 with QGIS, does not work, because it points
to the folder structure of GRASS 7.0.1.
I don't know if this has been corrected since then, and whether this might
be your problem. I am forwarding this thread also for QGIS mailing list.
Best regards,
Pedro Venâncio
2015-10-27 13:23 GMT+00:00 Veronica Andreo <veroandreo gmail.com>:
> Hi devs,
> me again, sorry...
> So, this comes from the previous email, but it is a different issue...
> I also got qgis stable (2.12) from osgeo4w 32bits installer and there
> seems to be NO grass plugin installed nor available in the plugin list.
> There's also NO grass tools in Processing and I have the latest version
> avilable. I guess I missed selecting some other things in the installation
> process, but don't know what.
> Any instruction is welcome! :)
> Cheers,
> Vero
> grass-dev mailing list
> grass-dev lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151027/32c458b0/attachment.html>
