[GRASS-dev] no grass plugin in qgis installed from osgeo4w
Veronica Andreo
veroandreo at gmail.com
Tue Oct 27 08:28:51 PDT 2015
Hi Stefan
2015-10-27 10:48 GMT-03:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> Hei Vero,
> Did you go through the advanced install in OSGeo4W? There you should have
> the “qgis-grass-plugin7” (and probably also necessary
> “qgis-grass-plugin-common”) available.
Yeah, advanced install... Meep! I forgot some some essential clicks,
maybe... ouch! Will try again and go back with news...
> For the shell issue you can have a look here:
> https://lists.osgeo.org/pipermail/grass-dev/2014-October/071294.html
will try :)
Is OSGeoLive DVD/USB an alternative for you? That may help to avoid a lot
> of trouble (esp. when prepared and provided by you), caused e.g. by user
> names with non-ascii characters, missing-dlls access rights…
I thought of it, but for the time being i'll try stick to local
installation of grass and qgis ()... I'd want/like them to learn grass and
then use/include it in their usual workflows... and not that they have to
start a virtual machine and change OS to use grass... they may do that for
some time but then, I feel they would drop it... Let's see how it goes :)
Thanks much, Stefan!
Cheers,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151027/bcb42706/attachment.html>
