[GRASS-dev] no grass plugin in qgis installed from osgeo4w
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Tue Oct 27 06:48:37 PDT 2015
Hei Vero,
Did you go through the advanced install in OSGeo4W? There you should have the “qgis-grass-plugin7” (and probably also necessary “qgis-grass-plugin-common”) available.
For the shell issue you can have a look here:
https://lists.osgeo.org/pipermail/grass-dev/2014-October/071294.html
Is OSGeoLive DVD/USB an alternative for you? That may help to avoid a lot of trouble (esp. when prepared and provided by you), caused e.g. by user names with non-ascii characters, missing-dlls access rights…
Cheers
Stefan
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Veronica Andreo
Sent: 27. oktober 2015 14:24
To: grass-dev <grass-dev at lists.osgeo.org>
Subject: [GRASS-dev] no grass plugin in qgis installed from osgeo4w
Hi devs,
me again, sorry...
So, this comes from the previous email, but it is a different issue...
I also got qgis stable (2.12) from osgeo4w 32bits installer and there seems to be NO grass plugin installed nor available in the plugin list.
There's also NO grass tools in Processing and I have the latest version avilable. I guess I missed selecting some other things in the installation process, but don't know what.
Any instruction is welcome! :)
Cheers,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151027/6790f6cc/attachment.html>
