[GRASS-dev] [GRASS GIS] #2783: mswindows / osgeo4w / grass.tmpl: OSGEO4W_ROOT_MSYS="@OSGEO4W_ROOT_MSYS@" not updated
trac at osgeo.org
Tue Oct 27 09:03:33 PDT 2015
not updated
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
FWIW taken from the ML dev
https://lists.osgeo.org/pipermail/grass-dev/2015-October/077033.html
>Then, I tested calling grass from MSYS shell, with the intention of
getting
some of linux shell funcionalities, >but the command grass70 does not
work... Attached, is a screenshot of the error i get...
the issue seems to be here:
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/grass.tmpl#L9
if I change this line in
C:\OSGeo4W_use\bin\grass71svn
to
OSGEO4W_ROOT_MSYS="$OSGEO4W_ROOT"
at least it: Starting GRASS GIS...
it seems @OSGEO4W_ROOT_MSYS@ is not replaced during packaging.
$OSGEO4W_ROOT is already set in an OSGeo4W environment.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2783>
