[GRASS-dev] no grass plugin in qgis installed from osgeo4w
Helmut Kudrnovsky
hellik at web.de
Tue Oct 27 09:17:37 PDT 2015
Veronica Andreo wrote
> Hi again :)
> 2015-10-27 12:15 GMT-03:00 Helmut Kudrnovsky <
> hellik@
>> AFAIK grass plugin isn't installed by OSGeo4W default installation.
>> start the OSGeo4W-setup -> advanced install -> Libs:
>> activate there:
>> qgis-grass plugin (for grass64)
>> qgis-grass plugin common
>> qgis-grass plugin7 (for grass7)
> So, i activated these libraries and now I get two different QGIS icons:
> one
> with grass6 and the other with grass7
> The one with grass6 works fine, both grass plugin and grass tools through
> processing are there and seem to work
> But, the one with grass7 does not have grass plugin installed nor in the
> available plugin list and, maybe because of that (?), grass tools through
> processing do not work and when trying to use any of them it opens a
> dialog
> box saying I need to configure grassgis7 folder... But there's no GRASS
> item in Configuration --> Options (maybe just because the grass plugin is
> not there), so I don't know where or if i even can do that without the
> grass plugin... sorry for ignorant here :(
> Thanks so much all of you for your help!
> Best,
> Vero
as maybe this is an packaging issue, so may better ask on the QGIS dev
and/or OSGeo4W ML (https://lists.osgeo.org/mailman/listinfo/osgeo4w-dev)
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/no-grass-plugin-in-qgis-installed-from-osgeo4w-tp5232796p5232866.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
