[GRASS-dev] compiling GRASS fails at configure, unable to locate GDAL library
Markus Neteler neteler at osgeo.org
Thu Oct 29 05:25:29 PDT 2015
On Thu, Oct 29, 2015 at 1:21 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> On Thu, Oct 29, 2015 at 12:10 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Thu, Oct 29, 2015 at 12:03 PM, Paulo van Breugel
>> > On 29-10-15 11:38, Markus Neteler wrote:
>> >> This is not recommended - instead use the GDAL-GRASS plugin to
>> >> disentangle them properly.
>> > Thanks Marcus for the feedback. Yes I did compile GDAL with GRASS
>> > support,
>> > mostly because using the GDAL-GRASS plugin has always been problematic,
>> ... indeed it is asking for troubles :)
>> That's why the plugin was developed.
> I know that is the idea. However, for me since I started to use GRASS 7 it
> has been the other way around for me.
Yes - but it was simply not working, so that's no surprise...
> Getting things to work with the plugin
> has always provided me with much more (unsolvable) trouble than the
> admittedly more cumbersome compiling GDAL with GRASS support route. The last
> time I gave it a try was about half a year or bit more ago I think, so
> perhaps things have improved since.
Probably yes:
September 2015
https://trac.osgeo.org/gdal/wiki/Release/1.11.3-News
--> Build (Unix)
    Support custom buildflags in GRASS plugin (#5850)
    GRASS 7.0.0 support (#5852)
> I still agree I should try to use the GDAL-GRASS plugin instead of using
> GDAL compiled with GRASS support. Will do that when I have a little bit more
> time at hand.
> Thanks for the feedback Marcus, appreciated.
You are welcome,
Markus
