[GRASS-dev] Planning of 7.0.2 release
Vaclav Petras
wenzeslaus at gmail.com
Fri Oct 30 08:55:15 PDT 2015
On Fri, Oct 30, 2015 at 11:15 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> 2015-10-30 9:42 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> > I'm still not convinced of
> > "Common formats import with reprojection"
> yes, it sounds a bit strange. But it corresponds better with other
> items like "Raw binary array import" and others. Ma
When in doubt, fallback to how menu items should look like in general which
is be a command, for example:
Open, Save as, Work offline, Print, Close window, Copy, Clear
The strange sound of "Common formats import" may be from the plural which
is necessary there (and perhaps also because it doesn't make much sense),
but the plural sounds OK in "Import common formats" (and it makes sense in
general). "Import of common formats" sounds OK too and perhaps it is even
grammatically more correct but "Import common formats" is shorter and it is
a command/order which is fits with the principles for menu.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151030/b1c593f1/attachment.html>
