[GRASS-dev] Planning of 7.0.2 release
Helmut Kudrnovsky
hellik at web.de
Sat Oct 31 03:18:54 PDT 2015
Markus Neteler wrote
> Hi devs,
> given the #2720 (r.in.gdal don't start on wingrass 7.0.1) being fixed
> along
> with
> other fixes, I would suggest to plan a followup release 7.0.2.
> As always, some open issues remain (either to be done or to be postponed),
> please check:
> https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.2tobebackported
> - r64877 <https://trac.osgeo.org/grass/changeset/64877> -
> grass/trunk/raster/r.patch: call Rast_cell_size just once, not for
> every
> cell
> - r62162 <https://trac.osgeo.org/grass/changeset/62162> -
> vector/v.generalize: add test for self-intersection, use
> Vect_line_intersection2()
> - r64404 <https://trac.osgeo.org/grass/changeset/64404> -
> libpython:
> move cmd list <-> tuple from wxGUI
> - r64406 <https://trac.osgeo.org/grass/changeset/64406> - wxGUI:
> replace
> utils cmd list <-> tuple by grass.script.gtask functions
> - What is the status of r65057
> <https://trac.osgeo.org/grass/changeset/65057>, #2626
> <https://trac.osgeo.org/grass/ticket/2626>, #2627
> <https://trac.osgeo.org/grass/ticket/2627>, #2628
> <https://trac.osgeo.org/grass/ticket/2628>, #2147
> <https://trac.osgeo.org/grass/ticket/2147> and #2655
> <https://trac.osgeo.org/grass/ticket/2655>?
> - r65634 <https://trac.osgeo.org/grass/changeset/65634> wxGUI
> source
> code compatibility
> - r65519 <https://trac.osgeo.org/grass/changeset/65519> temporal
> library: Store the default database connection as shell variable
> substitute
> to avoid wrong temporal database path's in cases the location was
> renamed
> or the path to the grass database changed.
> I didn't go through myself yet, but the respective authors may please
> comment (or just do it).
> thanks
> Markus
font paths aren't updated during a OSGeo4W-winGRASS installation, see:
https://trac.osgeo.org/grass/ticket/2784
(further d.* problems also mentioned in some other tickets)
in #2784 I've added a patch for trunk to do a g.mkfontcap run by
OSGeo4W-postinstall.bat in order to update the font paths.
as I'm travelling, can anyone review the few lines in the patch?
if applied and tested by an OSGeo4W-winGRASS trunk daily, it should be
backported to 7.0.2.RCx IMO.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Planning-of-7-0-2-release-tp5225086p5233679.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
