[GRASS-dev] Planning of 7.0.2 release
Helmut Kudrnovsky
hellik at web.de
Sat Oct 31 16:03:37 PDT 2015
Helmut Kudrnovsky wrote
> Markus Neteler wrote
>> Hi devs,
>> given the #2720 (r.in.gdal don't start on wingrass 7.0.1) being fixed
>> along
>> with
>> other fixes, I would suggest to plan a followup release 7.0.2.
>> As always, some open issues remain (either to be done or to be
>> postponed),
>> please check:
>> https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.2tobebackported
>> - r64877 <https://trac.osgeo.org/grass/changeset/64877> -
>> grass/trunk/raster/r.patch: call Rast_cell_size just once, not for
>> every
>> cell
>> - r62162 <https://trac.osgeo.org/grass/changeset/62162> -
>> vector/v.generalize: add test for self-intersection, use
>> Vect_line_intersection2()
>> - r64404 <https://trac.osgeo.org/grass/changeset/64404> -
>> libpython:
>> move cmd list <-> tuple from wxGUI
>> - r64406 <https://trac.osgeo.org/grass/changeset/64406> - wxGUI:
>> replace
>> utils cmd list <-> tuple by grass.script.gtask functions
>> - What is the status of r65057
>> <https://trac.osgeo.org/grass/changeset/65057>, #2626
>> <https://trac.osgeo.org/grass/ticket/2626>, #2627
>> <https://trac.osgeo.org/grass/ticket/2627>, #2628
>> <https://trac.osgeo.org/grass/ticket/2628>, #2147
>> <https://trac.osgeo.org/grass/ticket/2147> and #2655
>> <https://trac.osgeo.org/grass/ticket/2655>?
>> - r65634 <https://trac.osgeo.org/grass/changeset/65634> wxGUI
>> source
>> code compatibility
>> - r65519 <https://trac.osgeo.org/grass/changeset/65519> temporal
>> library: Store the default database connection as shell variable
>> substitute
>> to avoid wrong temporal database path's in cases the location was
>> renamed
>> or the path to the grass database changed.
>> I didn't go through myself yet, but the respective authors may please
>> comment (or just do it).
>> thanks
>> Markus
> font paths aren't updated during a OSGeo4W-winGRASS installation, see:
> https://trac.osgeo.org/grass/ticket/2784
> (further d.* problems also mentioned in some other tickets)
> in #2784 I've added a patch for trunk to do a g.mkfontcap run by
> OSGeo4W-postinstall.bat in order to update the font paths.
> as I'm travelling, can anyone review the few lines in the patch?
> if applied and tested by an OSGeo4W-winGRASS trunk daily, it should be
> backported to 7.0.2.RCx IMO.
from https://trac.osgeo.org/grass/ticket/2784#comment:4
"applied an slightly typo cleaned and prettified patch by r66691.
following file should be updated with the correct font paths.
C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\fontcap
please test upcoming OSGeo4W-winGRASS trunk dailies in the next days."
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Planning-of-7-0-2-release-tp5225086p5233741.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
