[GRASS-dev] [GRASS-SVN] r66014 - grass/trunk/lib/python/temporal
Markus Neteler
neteler at osgeo.org
Sat Sep 5 09:39:36 PDT 2015
Hi Soeren,
ich habe versucht, den relevanten Teil Deines fixes zu backporten:
https://trac.osgeo.org/grass/changeset/66115
Ich hoffe, dass es richtig ist..
Gruesse
Markus
On Tue, Aug 25, 2015 at 12:13 PM, <svn_grass at osgeo.org> wrote:
> Author: huhabla
> Date: 2015-08-25 03:13:30 -0700 (Tue, 25 Aug 2015)
> New Revision: 66014
> Modified:
> grass/trunk/lib/python/temporal/c_libraries_interface.py
> grass/trunk/lib/python/temporal/core.py
> grass/trunk/lib/python/temporal/space_time_datasets.py
> Log:
> temporal library: Fixed wrong mapset access method
> Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
> --- grass/trunk/lib/python/temporal/c_libraries_interface.py 2015-08-25 10:03:10 UTC (rev 66013)
> +++ grass/trunk/lib/python/temporal/c_libraries_interface.py 2015-08-25 10:13:30 UTC (rev 66014)
> @@ -151,15 +151,17 @@
> :returns: Names of available mapsets as list of strings
> count = 0
> mapset_list = []
> try:
> + # Initilaize the accessable mapset list, this is bad C design!!!
> + libgis.G_get_mapset_name(0)
> mapsets = libgis.G_get_available_mapsets()
> while mapsets[count]:
> char_list = ""
> mapset = mapsets[count]
> - if libgis.G_mapset_permissions(mapset) > 0:
> + if libgis.G_mapset_permissions(mapset) == 1 and libgis.G_is_mapset_in_search_path(mapset) == 1:
> c = 0
> while mapset[c] != "\x00":
> char_list += mapset[c]
> @@ -758,7 +760,7 @@
> CALLBACK.argtypes = c_void_p
> cerror_handler = CALLBACK(error_handler)
> libgis.G_add_error_handler(cerror_handler, None)
> # Crerate the function array
> @@ -914,17 +916,17 @@
> >>> mapset = ciface.get_mapset()
> >>> location = ciface.get_location()
> >>> gisdbase = ciface.get_gisdbase()
> >>> ciface.fatal_error()
> Traceback (most recent call last):
> raise FatalError(message)
> FatalError: Fatal error
> @@ -950,7 +952,7 @@
> self.start_server()
> self.start_checker_thread()
> self.stopThread = False
> def start_checker_thread(self):
> if self.checkThread is not None and self.checkThread.is_alive():
> self.stop_checker_thread()
> @@ -959,13 +961,13 @@
> self.checkThread.daemon = True
> self.checkThread.start()
> def stop_checker_thread(self):
> self.threadLock.acquire()
> self.stopThread = True
> self.threadLock.release()
> self.checkThread.join(None)
> def thread_checker(self):
> """Check every 200 micro seconds if the server process is alive"""
> while True:
> @@ -989,7 +991,7 @@
> def check_server(self):
> self._check_restart_server()
> def _check_restart_server(self):
> """Restart the server if it was terminated
> @@ -1351,7 +1353,7 @@
> def fatal_error(self, mapset=None):
> """Generate a fatal error in libgis.
> This function is only for testing purpose.
> self.check_server()
> @@ -1360,7 +1362,7 @@
> return self.safe_receive("Fatal error")
> def safe_receive(self, message):
> - """Receive the data and throw an FatalError exception in case the server
> + """Receive the data and throw an FatalError exception in case the server
> process was killed and the pipe was closed by the checker thread"""
> try:
> ret = self.client_conn.recv()
> Modified: grass/trunk/lib/python/temporal/core.py
> --- grass/trunk/lib/python/temporal/core.py 2015-08-25 10:03:10 UTC (rev 66013)
> +++ grass/trunk/lib/python/temporal/core.py 2015-08-25 10:13:30 UTC (rev 66014)
> @@ -750,7 +750,7 @@
> stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
> str3ds_tables_sql = stds_tables_template_sql.replace("STDS", "str3ds")
> - msgr.message(_("Creating temporal database: %s" % (tgis_database_string)))
> + msgr.message(_("Creating temporal database: %s" % (str(tgis_database_string))))
> if tgis_backend == "sqlite":
> # We need to create the sqlite3 database path if it does not exists
> @@ -860,7 +860,7 @@
> driver, dbstring = self.tgis_mapsets[mapset]
> if dbstring not in self.unique_connections.keys():
> - self.unique_connections[dbstring] = DBConnection(backend=driver,
> + self.unique_connections[dbstring] = DBConnection(backend=driver,
> dbstring=dbstring)
> self.connections[mapset] = self.unique_connections[dbstring]
> @@ -1025,7 +1025,7 @@
> def __init__(self, backend=None, dbstring=None):
> """ Constructor of a database connection
> param backend:The database backend sqlite or pg
> param dbstring: The database connection string
> @@ -1071,7 +1071,7 @@
> """Connect to the DBMI to execute SQL statements
> Supported backends are sqlite3 and postgresql
> # Connection in the current mapset
> Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
> --- grass/trunk/lib/python/temporal/space_time_datasets.py 2015-08-25 10:03:10 UTC (rev 66013)
> +++ grass/trunk/lib/python/temporal/space_time_datasets.py 2015-08-25 10:13:30 UTC (rev 66014)
> @@ -88,7 +88,7 @@
> >>> rmap.get_temporal_extent_as_tuple()
> (datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2012, 1, 1, 0, 0))
> >>> rmap.get_name()
> - 'strds_map_test_case'
> + u'strds_map_test_case'
> >>> rmap.get_mapset() == mapset
> True
> >>> rmap.get_temporal_type()
> @@ -407,7 +407,7 @@
> >>> r3map.get_temporal_extent_as_tuple()
> >>> r3map.get_name()
> - 'str3ds_map_test_case'
> + u'str3ds_map_test_case'
> >>> r3map.get_mapset() == mapset
> True
> >>> r3map.get_temporal_type()
> @@ -737,7 +737,7 @@
> >>> vmap.get_temporal_extent_as_tuple()
> >>> vmap.get_name()
> - 'stvds_map_test_case'
> + u'stvds_map_test_case'
> >>> vmap.get_mapset() == mapset
> True
> >>> vmap.get_temporal_type()
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
