[GRASS-dev] [GRASS-SVN] r66014 - grass/trunk/lib/python/temporal
    Sören Gebbert
    soerengebbert at googlemail.com
    Sat Sep  5 11:58:04 PDT 2015
Hi Markus,
looks good to me.
Ciao
Soeren
2015-09-05 18:39 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi Soeren,
> ich habe versucht, den relevanten Teil Deines fixes zu backporten:
> https://trac.osgeo.org/grass/changeset/66115
> Ich hoffe, dass es richtig ist..
> Gruesse
> Markus
> On Tue, Aug 25, 2015 at 12:13 PM,  <svn_grass at osgeo.org> wrote:
>> Author: huhabla
>> Date: 2015-08-25 03:13:30 -0700 (Tue, 25 Aug 2015)
>> New Revision: 66014
>> Modified:
>>    grass/trunk/lib/python/temporal/c_libraries_interface.py
>>    grass/trunk/lib/python/temporal/core.py
>>    grass/trunk/lib/python/temporal/space_time_datasets.py
>> Log:
>> temporal library: Fixed wrong mapset access method
>> Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
>> --- grass/trunk/lib/python/temporal/c_libraries_interface.py    2015-08-25 10:03:10 UTC (rev 66013)
>> +++ grass/trunk/lib/python/temporal/c_libraries_interface.py    2015-08-25 10:13:30 UTC (rev 66014)
>> @@ -151,15 +151,17 @@
>>         :returns: Names of available mapsets as list of strings
>>      count = 0
>>      mapset_list = []
>>      try:
>> +        # Initilaize the accessable mapset list, this is bad C design!!!
>> +        libgis.G_get_mapset_name(0)
>>          mapsets = libgis.G_get_available_mapsets()
>>          while mapsets[count]:
>>              char_list = ""
>>              mapset = mapsets[count]
>> -            if libgis.G_mapset_permissions(mapset) > 0:
>> +            if libgis.G_mapset_permissions(mapset) == 1 and libgis.G_is_mapset_in_search_path(mapset) == 1:
>>                  c = 0
>>                  while mapset[c] != "\x00":
>>                      char_list += mapset[c]
>> @@ -758,7 +760,7 @@
>>      CALLBACK.argtypes = c_void_p
>>      cerror_handler = CALLBACK(error_handler)
>>      libgis.G_add_error_handler(cerror_handler, None)
>>      # Crerate the function array
>> @@ -914,17 +916,17 @@
>>             >>> mapset = ciface.get_mapset()
>>             >>> location = ciface.get_location()
>>             >>> gisdbase = ciface.get_gisdbase()
>>             >>> ciface.fatal_error()
>>             Traceback (most recent call last):
>>                 raise FatalError(message)
>>             FatalError: Fatal error
>> @@ -950,7 +952,7 @@
>>          self.start_server()
>>          self.start_checker_thread()
>>          self.stopThread = False
>>      def start_checker_thread(self):
>>          if self.checkThread is not None and self.checkThread.is_alive():
>>              self.stop_checker_thread()
>> @@ -959,13 +961,13 @@
>>          self.checkThread.daemon = True
>>          self.checkThread.start()
>>      def stop_checker_thread(self):
>>          self.threadLock.acquire()
>>          self.stopThread = True
>>          self.threadLock.release()
>>          self.checkThread.join(None)
>>      def thread_checker(self):
>>          """Check every 200 micro seconds if the server process is alive"""
>>          while True:
>> @@ -989,7 +991,7 @@
>>      def check_server(self):
>>          self._check_restart_server()
>>      def _check_restart_server(self):
>>          """Restart the server if it was terminated
>> @@ -1351,7 +1353,7 @@
>>      def fatal_error(self, mapset=None):
>>          """Generate a fatal error in libgis.
>>              This function is only for testing purpose.
>>          self.check_server()
>> @@ -1360,7 +1362,7 @@
>>          return self.safe_receive("Fatal error")
>>      def safe_receive(self, message):
>> -        """Receive the data and throw an FatalError exception in case the server
>> +        """Receive the data and throw an FatalError exception in case the server
>>             process was killed and the pipe was closed by the checker thread"""
>>          try:
>>              ret = self.client_conn.recv()
>> Modified: grass/trunk/lib/python/temporal/core.py
>> --- grass/trunk/lib/python/temporal/core.py     2015-08-25 10:03:10 UTC (rev 66013)
>> +++ grass/trunk/lib/python/temporal/core.py     2015-08-25 10:13:30 UTC (rev 66014)
>> @@ -750,7 +750,7 @@
>>      stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
>>      str3ds_tables_sql = stds_tables_template_sql.replace("STDS", "str3ds")
>> -    msgr.message(_("Creating temporal database: %s" % (tgis_database_string)))
>> +    msgr.message(_("Creating temporal database: %s" % (str(tgis_database_string))))
>>      if tgis_backend == "sqlite":
>>          # We need to create the sqlite3 database path if it does not exists
>> @@ -860,7 +860,7 @@
>>              driver,  dbstring = self.tgis_mapsets[mapset]
>>              if dbstring not in self.unique_connections.keys():
>> -                self.unique_connections[dbstring] = DBConnection(backend=driver,
>> +                self.unique_connections[dbstring] = DBConnection(backend=driver,
>>        dbstring=dbstring)
>>              self.connections[mapset] = self.unique_connections[dbstring]
>> @@ -1025,7 +1025,7 @@
>>      def __init__(self, backend=None, dbstring=None):
>>          """ Constructor of a database connection
>>              param backend:The database backend sqlite or pg
>>              param dbstring: The database connection string
>> @@ -1071,7 +1071,7 @@
>>          """Connect to the DBMI to execute SQL statements
>>              Supported backends are sqlite3 and postgresql
>>          # Connection in the current mapset
>> Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
>> --- grass/trunk/lib/python/temporal/space_time_datasets.py      2015-08-25 10:03:10 UTC (rev 66013)
>> +++ grass/trunk/lib/python/temporal/space_time_datasets.py      2015-08-25 10:13:30 UTC (rev 66014)
>> @@ -88,7 +88,7 @@
>>              >>> rmap.get_temporal_extent_as_tuple()
>>              (datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2012, 1, 1, 0, 0))
>>              >>> rmap.get_name()
>> -            'strds_map_test_case'
>> +            u'strds_map_test_case'
>>              >>> rmap.get_mapset() == mapset
>>              True
>>              >>> rmap.get_temporal_type()
>> @@ -407,7 +407,7 @@
>>              >>> r3map.get_temporal_extent_as_tuple()
>>              >>> r3map.get_name()
>> -            'str3ds_map_test_case'
>> +            u'str3ds_map_test_case'
>>              >>> r3map.get_mapset() == mapset
>>              True
>>              >>> r3map.get_temporal_type()
>> @@ -737,7 +737,7 @@
>>              >>> vmap.get_temporal_extent_as_tuple()
>>              >>> vmap.get_name()
>> -            'stvds_map_test_case'
>> +            u'stvds_map_test_case'
>>              >>> vmap.get_mapset() == mapset
>>              True
>>              >>> vmap.get_temporal_type()
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-commit
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
