[GRASS-dev] [GRASS GIS] #2733: Add travis-ci automated testing for OS X to existing Linux testing
GRASS GIS trac at osgeo.org
Mon Sep 7 00:46:11 PDT 2015
 Reporter:  rkrug        |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  normal       |  Milestone:
Component:  Default      |    Version:  svn-trunk
 Keywords:               |        CPU:  Unspecified
 Platform:  All          |
 This patch adds support for testing of grass head branch for OS X on
 travis-ci.
 Continuous integreation (see [https://github.com/GRASS-GIS/grass-ci] and
 [https://travis-ci.org/GRASS-GIS/grass-ci]) was only done for Linux.
 With this patch, tests are also done for OS X using homebrew.
 The tests are running (see [https://travis-ci.org/rkrug/grass-ci]).
 In addition to applying this patch, the multiplatform support needs to be
 enabled for travis-ci which has to be done by mailing travis-ci support.
 Effectively, I have done the following:
 1) moved the linux test section into separate script files
 2) created equivalent ones for OS X
 3) changed the .travis.yml file to call the scripts depending on the OS
 running
 At the moment only installation is tested, but adding support for tests is
 trivial, but details questions concerning which tests, if the results can
 be uploaded, ... need to be decided.
 The same can done for other branches as well.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2733>
