[GRASS-dev] addon mismatch
Paulo van Breugel p.vanbreugel at gmail.com
Fri Sep 11 10:13:03 PDT 2015
On 11-09-15 18:56, Markus Neteler wrote:
> On Fri, Sep 11, 2015 at 12:48 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> A related / similar issue, I have added an add-on
>> https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.biodiversity
>> and added it to the parent Make file. I can't recall having done anything
>> else then just uploading an add-on in the past, but it is not available
>> through g.extension,
> Yes it is!
> GRASS 7.1.svn (eu_laea):~ > g.extension r.biodiversity
> Fetching <r.biodiversity> from GRASS GIS Addons repository (be patient)...
> Compiling...
> Installing...
> Updating addons metadata file...
> WARNING: No addons metadata available. Addons metadata file not updated.
> Installation of <r.biodiversity> successfully finished
You are right :-) on the command line it worked. I had only checked
using the g.extension GUI, where the extension is not shown
Markus
PS: no idea what "WARNING: No addons metadata available. Addons
metadata file not updated." means
No clue either, but maybe the reason it doesn't show in the g.extension GUI?
