[GRASS-dev] Some wxPython 3 issues
Anna Petrášová
kratochanna at gmail.com
Thu Sep 17 14:47:18 PDT 2015
On Thu, Sep 17, 2015 at 5:04 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Sep 17, 2015 at 7:13 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > On Thu, Sep 17, 2015 at 6:42 AM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >> - wxpython3_textfield_bug.jpg: this is in the bulk raster import, the
> >> change of name during import is not readable (the text field is of one
> >> pixel height, see red ellipsis in the screenshot
> > What do you think is the "actual text".
> We tried to replace the upper name. But it remains while a few pixels,
> as highlighted in red, got shown (of course unreadable).
> > I see the names there, they are
> > perhaps wrong (split by first dot) but they are there (in your
> screenshot).
> No, that are the old names we wanted to change.
> > The marked thing looks like some rendering glitch.
> Indeed that is the textfield at editing time :(
> >> - the selector button is not much readable in the map layer manager as
> >> well as some other places (red indication in screenshot) but there is
> >> a nice tick box in the same bulk raster import dialog which might be
> >> used everywhere (green indication). This would help a lot.
> > The difference is caused by simple native versus some advanced
> rendering. As
> > with many other bugs you've reported earlier, the only way I see is to
> look
> > to wxPython demo application which contains all possible widgets and see
> if
> > the issue is there as well
> ok done:
> dnf -y install wxPython-docs
> python /usr/share/doc/wxPython-docs/demo/CheckBox.py
> Python 2.7.10 (default, Jul 5 2015, 14:15:43)
> [GCC 5.1.1 20150618 (Red Hat 5.1.1-4)]
> wx.version: 3.0.2.0 gtk3 (classic)
> The demo looks perfect (see screenshot) as in the lower part of the
> bulk importer. So seems to be a GRASS issue. Perhaps the wx.CheckBox()
> changes the style somehow unintentionally?
It's not the standard native checkbox, you should look for
CheckListCtrlMixin. For the editing issue, look for ListCtrl_edit in the
demo (I used 2.8 demo, so hopefully it has the same name in wpython 3 demo).
Anna
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150917/7ccd6064/attachment.html>
