[GRASS-dev] r.in.lidar not running in Mac binaries for 7.1
Michael Barton
Michael.Barton at asu.edu
Thu Sep 17 17:52:16 PDT 2015
So let me explain where I’m at with libLAS.
I recompiled boost 1.5.4 for 64 bit only (it will no longer compile 32_64 it seems) and fixed a known error in boost (manually delete the comma at the end of the list on line 117 of /boost-snow/include/boost/interprocess/errors.hpp)
I’ve got libLAS 1.8
Here is the workflow I used last time.
cd to liblas source folder
mkdir makefiles
cd makefiles
export BOOST_ROOT="/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/boost-snow” ## my path to boost
Then I run cmake
Originally, I did this
cmake -G "Unix Makefiles" -D CMAKE_OSX_ARCHITECTURES=“i386;x86_64" -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk” -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Programs/gdal-config -D GEOTIFF_INCLUDE_DIR=/Library/Frameworks/UnixImageIO.framework/unix/include -D GEOTIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib ../
cmake ran fine, but make bombed with
>clang: error: invalid arch name '-arch “i386’
So I tried it 64 bit only since I compiled boost for 64 bit only.
cmake -G "Unix Makefiles" -D CMAKE_OSX_ARCHITECTURES=“x86_64" -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk” -D GDAL_CONFIG="/Library/Frameworks/GDAL.framework/Programs/gdal-config" -D GEOTIFF_INCLUDE_DIR="/Library/Frameworks/UnixImageIO.framework/unix/include" -D GEOTIFF_LIBRARY="/Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib" -D CMAKE_VERBOSE_MAKEFILE=true ../
Again, cmake is fine but make bombed. Here is the complete error
-- The C compiler identification is Clang 5.1.0
-- The CXX compiler identification is Clang 5.1.0
CMake Warning at /Applications/CMake 2.8-12.app/Contents/share/cmake-2.8/Modules/Platform/Darwin.cmake:179 (message):
Ignoring CMAKE_OSX_SYSROOT value:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.10.sdk
because the directory does not exist.
Call Stack (most recent call first):
/Applications/CMake 2.8-12.app/Contents/share/cmake-2.8/Modules/CMakeSystemSpecificInformation.cmake:36 (include)
CMakeLists.txt:9 (project)
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - failed
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - failed
-- Setting libLAS build type - Release
-- Searching for Boost 1.38+ - done
-- Looking for include file pthread.h
-- Looking for include file pthread.h - not found
-- Could NOT find Threads (missing: Threads_FOUND)
-- Boost version: 1.54.0
-- Found the following Boost libraries:
-- program_options
-- thread
-- system
-- iostreams
-- filesystem
-- Searching for LASzip 2.0.1+ library
-- Could NOT find LASzip (missing: LASZIP_LIBRARY LASZIP_INCLUDE_DIR) (Required is at least version "2.0.1")
-- Searching for GDAL 1.7.0+ library
-- Found acceptable GDAL version 1.11.2
-- Found GDAL: /lib.dylib (Required is at least version "1.7.0")
-- Searching for GeoTIFF 1.2.5+ library
-- Found GeoTIFF version: 1.4.0
-- Found GeoTIFF: /Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib (Required is at least version "1.2.5")
-- Found TIFF: /opt/local/lib/libtiff.dylib (found version "3.9.5")
-- Enable libLAS utilities to build - done
-- Enable libLAS unit tests to build - done
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles
cmb-imaccsdc:makefiles cmbarton$ make
"/Applications/CMake 2.8-12.app/Contents/bin/cmake" -H/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0 -B/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles --check-build-system CMakeFiles/Makefile.cmake 0
"/Applications/CMake 2.8-12.app/Contents/bin/cmake" -E cmake_progress_start /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/CMakeFiles /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/CMakeFiles/progress.marks
/Applications/Xcode.app/Contents/Developer/usr/bin/make -f CMakeFiles/Makefile2 all
/Applications/Xcode.app/Contents/Developer/usr/bin/make -f src/CMakeFiles/las.dir/build.make src/CMakeFiles/las.dir/depend
cd /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles && "/Applications/CMake 2.8-12.app/Contents/bin/cmake" -E cmake_depends "Unix Makefiles" /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0 /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/src /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/src /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/src/CMakeFiles/las.dir/DependInfo.cmake --color=
Scanning dependencies of target las
/Applications/Xcode.app/Contents/Developer/usr/bin/make -f src/CMakeFiles/las.dir/build.make src/CMakeFiles/las.dir/build
"/Applications/CMake 2.8-12.app/Contents/bin/cmake" -E cmake_progress_report /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/CMakeFiles 3
[ 1%] Building CXX object src/CMakeFiles/las.dir/detail/index/indexcell.cpp.o
cd /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/src && /usr/bin/c++ -DHAVE_GDAL=1 -DHAVE_LIBGEOTIFF=1 -Dlas_EXPORTS -stdlib=libstdc++ -Wextra -Wall -Wno-unused-parameter -Wno-unused-variable -Wpointer-arith -Wcast-align -Wcast-qual -Wfloat-equal -Wredundant-decls -Wno-long-long -O3 -DNDEBUG -arch “x86_64 -D CMAKE_OSX_SYSROOT=/Developer/SDKs/MacOSX10.7.sdk” -fPIC -I/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/src/../include -I/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/boost-snow/include -I/Library/Frameworks/GDAL.framework/Headers -I/Library/Frameworks/UnixImageIO.framework/unix/include -I/opt/local/include -o CMakeFiles/las.dir/detail/index/indexcell.cpp.o -c /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/src/detail/index/indexcell.cpp
clang: error: invalid arch name '-arch “x86_64'
make[2]: *** [src/CMakeFiles/las.dir/detail/index/indexcell.cpp.o] Error 1
make[1]: *** [src/CMakeFiles/las.dir/all] Error 2
make: *** [all] Error 2
It looks like it is misreading the architecture flag value
I’ve tried it without quotes around x86_64 and it acts like there are unmatched quotes in the configure string. But there are not. Is there a bug somewhere in a configure file? Where??? I can’t find any file with the CMAKE_OSX_ARCHITECTURES flag to look at.
I’m completely stumped.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 16, 2015, at 7:22 AM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
On Wed, Sep 16, 2015 at 9:41 AM, William Kyngesburye <woklist at kyngchaos.com<mailto:woklist at kyngchaos.com>> wrote:
So the question is if GRASS supports one or the other library or both, or does it also use the tools in a script so it doesn't matter.
GRASS uses only the library, not the tools, and is designed/tested/known to work only with libLAS.
I suppose there never was a need or will to compile it with LASlib which is coupled with partially non-FOSS LAStools (and you would need the FOSS libLAS' tools anyway).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150918/7e9bda7a/attachment-0001.html>
