[GRASS-dev] r.in.lidar not running in Mac binaries for 7.1
William Kyngesburye
woklist at kyngchaos.com
Thu Sep 17 20:18:36 PDT 2015
Your arch option in cmake starts with a curly quote, so it's seeing that as a plain character, not a quote. Same with the SDK option (ends with curly quote).
On Sep 17, 2015, at 7:52 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> So let me explain where I’m at with libLAS.
> I recompiled boost 1.5.4 for 64 bit only (it will no longer compile 32_64 it seems) and fixed a known error in boost (manually delete the comma at the end of the list on line 117 of /boost-snow/include/boost/interprocess/errors.hpp)
> I’ve got libLAS 1.8
> Here is the workflow I used last time.
> cd to liblas source folder
> mkdir makefiles
> cd makefiles
> export BOOST_ROOT="/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/boost-snow” ## my path to boost
> Then I run cmake
> Originally, I did this
> cmake -G "Unix Makefiles" -D CMAKE_OSX_ARCHITECTURES=“i386;x86_64" -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk” -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Programs/gdal-config -D GEOTIFF_INCLUDE_DIR=/Library/Frameworks/UnixImageIO.framework/unix/include -D GEOTIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib ../
> cmake ran fine, but make bombed with
> >clang: error: invalid arch name '-arch “i386’
> So I tried it 64 bit only since I compiled boost for 64 bit only.
> cmake -G "Unix Makefiles" -D CMAKE_OSX_ARCHITECTURES=“x86_64" -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk” -D GDAL_CONFIG="/Library/Frameworks/GDAL.framework/Programs/gdal-config" -D GEOTIFF_INCLUDE_DIR="/Library/Frameworks/UnixImageIO.framework/unix/include" -D GEOTIFF_LIBRARY="/Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib" -D CMAKE_VERBOSE_MAKEFILE=true ../
> Again, cmake is fine but make bombed. Here is the complete error
> -- The C compiler identification is Clang 5.1.0
> -- The CXX compiler identification is Clang 5.1.0
> CMake Warning at /Applications/CMake 2.8-12.app/Contents/share/cmake-2.8/Modules/Platform/Darwin.cmake:179 (message):
> Ignoring CMAKE_OSX_SYSROOT value:
> /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.10.sdk
> because the directory does not exist.
> Call Stack (most recent call first):
> /Applications/CMake 2.8-12.app/Contents/share/cmake-2.8/Modules/CMakeSystemSpecificInformation.cmake:36 (include)
> CMakeLists.txt:9 (project)
> -- Check for working C compiler: /usr/bin/cc
> -- Check for working C compiler: /usr/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - failed
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - failed
> -- Setting libLAS build type - Release
> -- Searching for Boost 1.38+ - done
> -- Looking for include file pthread.h
> -- Looking for include file pthread.h - not found
> -- Could NOT find Threads (missing: Threads_FOUND)
> -- Boost version: 1.54.0
> -- Found the following Boost libraries:
> -- program_options
> -- thread
> -- system
> -- iostreams
> -- filesystem
> -- Searching for LASzip 2.0.1+ library
> -- Could NOT find LASzip (missing: LASZIP_LIBRARY LASZIP_INCLUDE_DIR) (Required is at least version "2.0.1")
> -- Searching for GDAL 1.7.0+ library
> -- Found acceptable GDAL version 1.11.2
> -- Found GDAL: /lib.dylib (Required is at least version "1.7.0")
> -- Searching for GeoTIFF 1.2.5+ library
> -- Found GeoTIFF version: 1.4.0
> -- Found GeoTIFF: /Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib (Required is at least version "1.2.5")
> -- Found TIFF: /opt/local/lib/libtiff.dylib (found version "3.9.5")
> -- Enable libLAS utilities to build - done
> -- Enable libLAS unit tests to build - done
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles
> cmb-imaccsdc:makefiles cmbarton$ make
> "/Applications/CMake 2.8-12.app/Contents/bin/cmake" -H/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0 -B/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles --check-build-system CMakeFiles/Makefile.cmake 0
> "/Applications/CMake 2.8-12.app/Contents/bin/cmake" -E cmake_progress_start /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/CMakeFiles /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/CMakeFiles/progress.marks
> /Applications/Xcode.app/Contents/Developer/usr/bin/make -f CMakeFiles/Makefile2 all
> /Applications/Xcode.app/Contents/Developer/usr/bin/make -f src/CMakeFiles/las.dir/build.make src/CMakeFiles/las.dir/depend
> cd /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles && "/Applications/CMake 2.8-12.app/Contents/bin/cmake" -E cmake_depends "Unix Makefiles" /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0 /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/src /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/src /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/src/CMakeFiles/las.dir/DependInfo.cmake --color=
> Scanning dependencies of target las
> /Applications/Xcode.app/Contents/Developer/usr/bin/make -f src/CMakeFiles/las.dir/build.make src/CMakeFiles/las.dir/build
> "/Applications/CMake 2.8-12.app/Contents/bin/cmake" -E cmake_progress_report /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/CMakeFiles 3
> [ 1%] Building CXX object src/CMakeFiles/las.dir/detail/index/indexcell.cpp.o
> cd /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/makefiles/src && /usr/bin/c++ -DHAVE_GDAL=1 -DHAVE_LIBGEOTIFF=1 -Dlas_EXPORTS -stdlib=libstdc++ -Wextra -Wall -Wno-unused-parameter -Wno-unused-variable -Wpointer-arith -Wcast-align -Wcast-qual -Wfloat-equal -Wredundant-decls -Wno-long-long -O3 -DNDEBUG -arch “x86_64 -D CMAKE_OSX_SYSROOT=/Developer/SDKs/MacOSX10.7.sdk” -fPIC -I/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/src/../include -I/Users/cmbarton/Dropbox/GRASS_dropbox/compiling/boost-snow/include -I/Library/Frameworks/GDAL.framework/Headers -I/Library/Frameworks/UnixImageIO.framework/unix/include -I/opt/local/include -o CMakeFiles/las.dir/detail/index/indexcell.cpp.o -c /Users/cmbarton/Dropbox/GRASS_dropbox/compiling/libLAS-1.8.0/src/detail/index/indexcell.cpp
> clang: error: invalid arch name '-arch “x86_64'
> make[2]: *** [src/CMakeFiles/las.dir/detail/index/indexcell.cpp.o] Error 1
> make[1]: *** [src/CMakeFiles/las.dir/all] Error 2
> make: *** [all] Error 2
> It looks like it is misreading the architecture flag value
> I’ve tried it without quotes around x86_64 and it acts like there are unmatched quotes in the configure string. But there are not. Is there a bug somewhere in a configure file? Where??? I can’t find any file with the CMAKE_OSX_ARCHITECTURES flag to look at.
> I’m completely stumped.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Sep 16, 2015, at 7:22 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Wed, Sep 16, 2015 at 9:41 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> So the question is if GRASS supports one or the other library or both, or does it also use the tools in a script so it doesn't matter.
>> GRASS uses only the library, not the tools, and is designed/tested/known to work only with libLAS.
>> I suppose there never was a need or will to compile it with LASlib which is coupled with partially non-FOSS LAStools (and you would need the FOSS libLAS' tools anyway).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
