[GRASS-dev] importing & projecting
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Sep 18 04:34:36 PDT 2015
I imported raster layers in a projected mapset, while the data layers
were in latlon. I used the r.in.gdal from the menu (i.e., not command
line), importing all geotif files in a directory.
I would have assumed that GRASS would throw an error as the layers were
not in the correct projection. Instead GRASS just imported the layers,
projecting the layers 'on the fly'.
A very convenient option , but I wonder if it shouldn't be an option
that should be explicitly selected by the user?
Paulo
