[GRASS-dev] importing & projecting
Moritz Lennert
mlennert at club.worldonline.be
Tue Sep 22 05:19:28 PDT 2015
On 18/09/15 13:34, Paulo van Breugel wrote:
> I imported raster layers in a projected mapset, while the data layers
> were in latlon. I used the r.in.gdal from the menu (i.e., not command
> line), importing all geotif files in a directory.
> I would have assumed that GRASS would throw an error as the layers were
> not in the correct projection. Instead GRASS just imported the layers,
> projecting the layers 'on the fly'.
> A very convenient option , but I wonder if it shouldn't be an option
> that should be explicitly selected by the user?
I very strongly agree and I think that such an important decision should
have been discussed on the ML (if it was, sorry, I must have missed it).
The relevant changes, AFAICT, are r65751 (v.import) and r65917 (r.import).
I don't have a strong opinion on this, but I think that there is some
advantage to GRASS telling the user that the file she is trying to
import is in a different projection than the location and that explicit
use of v./r.import would necessary.
Now the import wizard just silently imports anything without even
informing the user that reprojection is happening. This does not always
make sense and is a potential path to many disasters...
Projection handling is not easy, but IMHO it is one of the strengths of
GRASS to force the user to think about it. I agree that r./v.import are
a very nice convenience, but their use should at least result from a
conscious decision, not out of ignorance...
Moritz
