[GRASS-dev] Planning of 7.0.2 release
Markus Neteler
neteler at osgeo.org
Sun Sep 20 11:07:49 PDT 2015
Hi devs,
given the #2720 (r.in.gdal don't start on wingrass 7.0.1) being fixed along
with
other fixes, I would suggest to plan a followup release 7.0.2.
As always, some open issues remain (either to be done or to be postponed),
please check:
https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.2tobebackported
- r64877 <https://trac.osgeo.org/grass/changeset/64877> -
grass/trunk/raster/r.patch: call Rast_cell_size just once, not for every
cell
- r62162 <https://trac.osgeo.org/grass/changeset/62162> -
vector/v.generalize: add test for self-intersection, use
Vect_line_intersection2()
- r64404 <https://trac.osgeo.org/grass/changeset/64404> - libpython:
move cmd list <-> tuple from wxGUI
- r64406 <https://trac.osgeo.org/grass/changeset/64406> - wxGUI: replace
utils cmd list <-> tuple by grass.script.gtask functions
- What is the status of r65057
<https://trac.osgeo.org/grass/changeset/65057>, #2626
<https://trac.osgeo.org/grass/ticket/2626>, #2627
<https://trac.osgeo.org/grass/ticket/2627>, #2628
<https://trac.osgeo.org/grass/ticket/2628>, #2147
<https://trac.osgeo.org/grass/ticket/2147> and #2655
<https://trac.osgeo.org/grass/ticket/2655>?
- r65634 <https://trac.osgeo.org/grass/changeset/65634> wxGUI source
code compatibility
- r65519 <https://trac.osgeo.org/grass/changeset/65519> temporal
library: Store the default database connection as shell variable substitute
to avoid wrong temporal database path's in cases the location was renamed
or the path to the grass database changed.
I didn't go through myself yet, but the respective authors may please
comment (or just do it).
thanks
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150920/2e8b27e9/attachment.html>
