[GRASS-dev] Planning of 7.0.2 release
Laurent C.
lrntct at gmail.com
Sun Sep 20 12:36:10 PDT 2015
May I suggest to include a fix to r2688:
https://trac.osgeo.org/grass/ticket/2688
I don't think it can break anything. And it will prevent me to patch
GRASS each time I make an update ;)
Thanks,
Laurent
2015-09-20 19:07 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> Hi devs,
> given the #2720 (r.in.gdal don't start on wingrass 7.0.1) being fixed along
> with
> other fixes, I would suggest to plan a followup release 7.0.2.
> As always, some open issues remain (either to be done or to be postponed),
> please check:
> https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.2tobebackported
> r64877 - grass/trunk/raster/r.patch: call Rast_cell_size just once, not for
> every cell
> r62162 - vector/v.generalize: add test for self-intersection, use
> Vect_line_intersection2()
> r64404 - libpython: move cmd list <-> tuple from wxGUI
> r64406 - wxGUI: replace utils cmd list <-> tuple by grass.script.gtask
> functions
> What is the status of r65057, #2626, #2627, #2628, #2147 and #2655?
> r65634 wxGUI source code compatibility
> r65519 temporal library: Store the default database connection as shell
> variable substitute to avoid wrong temporal database path's in cases the
> location was renamed or the path to the grass database changed.
> I didn't go through myself yet, but the respective authors may please
> comment (or just do it).
> thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
