[GRASS-dev] [GRASS GIS] #2746: g.gui.vdigit fails to start with "PyAssertionError: C++ assertion "GetEventHandler() == this" failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed" (was: GUI fails to start: wx3.0 issue ?)
trac at osgeo.org
Mon Sep 21 04:07:00 PDT 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: g.gui.vdigit digitizer
CPU: Unspecified | Platform: Linux
Changes (by mlennert):
* keywords: g.gui wxgui => g.gui.vdigit digitizer
* version: svn-releasebranch70 => svn-trunk
* milestone: 7.0.2 => 7.1.0
Comment:
Replying to [comment:2 annakrat]:
> Do you have anything in ~/.grass7/toolboxes? I suspect you have there
menu xml file generated for trunk, which fails because tplot is not in
G70.
That's it for the g.gui issue in g70. Thanks !
However, the error when launching g.gui.vdigit in trunk remains (with
fresh check out at r66264). I don't have this problem in g70.
I've changed the title and parameters of this ticket to reflect that.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2746#comment:3>
