[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#289 (master - df4ce5c)
Markus Neteler
neteler at osgeo.org
Mon Sep 21 09:47:09 PDT 2015
one has to check the *raw* log to find it:
https://travis-ci.org/GRASS-GIS/grass-ci/builds/81415377
--> Build Jobs
--> 289.1
--> scroll down!
--> This log is too long to be displayed. Please reduce
the verbosity
of your build or download the *raw log*
==> https://s3.amazonaws.com/archive.travis-ci.org/jobs/81415379/log.txt
make[3]: Entering directory `/home/travis/build/GRASS-GIS/grass-ci/man'
GISBASE="/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu"
ARCH="x86_64-pc-linux-gnu"
ARCH_DISTDIR="/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu"
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python ./build_full_index.py
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python ./build_index.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/index.html
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python ./build_topics.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/full_index.html
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python ./build_keywords.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/topics.html
./build_graphical_index.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/graphical_index.html
./build_manual_gallery.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/keywords.html
./build_class_graphical.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/class_graphical.html
./parser_standard_options.py -t ../lib/gis/parser_standard_options.c
-f grass -o /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html
-p 'id="opts_table" class="scroolTable"'
File "./parser_standard_options.py", line 157, in <module>
args = parser.parse_args()
File "/usr/lib/python2.7/argparse.py", line 1688, in parse_args
args, argv = self.parse_known_args(args, namespace)
File "/usr/lib/python2.7/argparse.py", line 1710, in parse_known_args
default = self._get_value(action, default)
File "/usr/lib/python2.7/argparse.py", line 2239, in _get_value
raise ArgumentError(action, msg)
argparse.ArgumentError: argument -t/--text: can't open '': [Errno 2]
No such file or directory: ''
make[3]: *** [/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html]
Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory `/home/travis/build/GRASS-GIS/grass-ci/man'
make[2]: *** [default] Error 2
(anyone editing this may also fix the typo "scroolTable" --> "scrollTable")
Markus
