[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#289 (master - df4ce5c)
Martin Landa landa.martin at gmail.com
Mon Sep 21 09:50:06 PDT 2015
2015-09-21 18:47 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> ./parser_standard_options.py -t ../lib/gis/parser_standard_options.c
> -f grass -o /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html
> -p 'id="opts_table" class="scroolTable"'
> Traceback (most recent call last):
>   File "./parser_standard_options.py", line 157, in <module>
>     args = parser.parse_args()
>   File "/usr/lib/python2.7/argparse.py", line 1688, in parse_args
>     args, argv = self.parse_known_args(args, namespace)
>   File "/usr/lib/python2.7/argparse.py", line 1710, in parse_known_args
>     default = self._get_value(action, default)
>   File "/usr/lib/python2.7/argparse.py", line 2239, in _get_value
>     raise ArgumentError(action, msg)
> argparse.ArgumentError: argument -t/--text: can't open '': [Errno 2]
> No such file or directory: ''
> make[3]: *** [/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html]
> Error 1
> make[3]: *** Waiting for unfinished jobs....
> make[3]: Leaving directory `/home/travis/build/GRASS-GIS/grass-ci/man'
> make[2]: *** [default] Error 2
right, this is a know issue [1]. Martin
[1] https://lists.osgeo.org/pipermail/grass-dev/2015-September/076392.html
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
