[GRASS-dev] Collecting ideas for training manual for GRASS GIS
Moritz Lennert
mlennert at club.worldonline.be
Tue Sep 22 05:40:15 PDT 2015
On 18/09/15 06:26, Luca Delucchi wrote:
> On 18 September 2015 at 04:45, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> (Was: Re: [GRASS-dev] FOSS4G 2016 code sprint)
>> Hi Moritz and Luca,
> Hi Vaclav,
>>> We could also start a discussion about the software to use and create
>>> a repository and try to start to centralize the material already
>>> existing
>> from technical point of view, we are now using HTML pages (which can be
>> tutorials as well, not only manual pages), wiki and then all other things.
>> If we want to allow for an internationalization, that's yet another
>> question.
I think we should really look at the QGIS example for inspiration. The
system works quite well, uses sphynx, and allows creation of HTML and
PDF [1].
We might even consider using (at least some chapters of) the QGIS
training manual and adapt it to GRASS...
> internationalization is the main topic, I think, we should provide it or not?
I think that we should think the infrastructure in a way that makes it
easy to translate. It will then be up to the language communities to
organise translation if they want to. I think both the French and German
communities are quite active on that level, for example.
> for some reason yes, newbie some times would like to have material in
> their native language, for some other reason is really difficult to
> maintain it updated because people start to work on it and after
> disappear.
We can then show a mixed version, with only the translated parts shown
in the desired language, the rest in English. This is how it works for
the QGIS manuals.
> Use some simple tool as Transfixer [0] maybe could be useful
Yes, I think so. This makes translation really easy and allows anyone to
participate (e.g. easy organisation of translation sprints).
>> Ideally, the things should be in the OSGeo Educational Content Inventory and
>> we should be adding the stable or valuable things there as we are collecting
>> them.
+1 (but let's create it first ! ;-)
Moritz
[1]
https://github.com/qgis/QGIS-Documentation/tree/master/source/docs/training_manual
