[GRASS-dev] [GRASS GIS] #2746: g.gui.vdigit fails to start with "PyAssertionError: C++ assertion "GetEventHandler() == this" failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed"
trac at osgeo.org
Mon Sep 28 01:39:12 PDT 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: g.gui.vdigit digitizer
CPU: Unspecified | Platform: Linux
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:4 annakrat]:
> Replying to [comment:3 mlennert]:
> > Replying to [comment:2 annakrat]:
> > > Do you have anything in ~/.grass7/toolboxes? I suspect you have
there menu xml file generated for trunk, which fails because tplot is not
in G70.
> > That's it for the g.gui issue in g70. Thanks !
> > However, the error when launching g.gui.vdigit in trunk remains (with
fresh check out at r66264). I don't have this problem in g70.
> > I've changed the title and parameters of this ticket to reflect that.
> Should be fixed in r66351.
Yes, it is, thank you !
IIUC, this does not need to be ported to release70, so I'm closing the
ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2746#comment:5>
