[GRASS-dev] Write array to (point) attribute table
Paulo van Breugel p.vanbreugel at gmail.com
Wed Sep 30 08:20:06 PDT 2015
On 30-09-15 16:18, Anna Petrášová wrote:
> On Wed, Sep 30, 2015 at 9:27 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>     On Wed, Sep 30, 2015 at 11:53 AM, Pietro <peter.zamb at gmail.com
>     <mailto:peter.zamb at gmail.com>> wrote:
>         On Wed, Sep 30, 2015 at 9:51 AM, Paulo van Breugel
>         > On Wed, Sep 30, 2015 at 2:02 AM, Anna Petrášová
>         <kratochanna at gmail.com <mailto:kratochanna at gmail.com>>
>         > wrote:
>         >> On Tue, Sep 29, 2015 at 6:09 PM, Paulo van Breugel
>         >>> This must be a very basic question, but I can't find an
>         easy/direct way
>         >>> to do this. In python, if I have an array with values with
>         a length equal to
>         >>> the number of rows in an attribute table of a (point)
>         vector layer, how can
>         >>> I write those values to a new column in that attribute
>         table. I can of
>         >>> course first create the column, but than how to update
>         that column with the
>         >>> values in the array?
>         >> it should be pretty easy to do with pygrass, unfortunately
>         there is no
>         >> example on assigning attributes in the official
>         documentation [1],  but it
>         >> should be pretty easy, something like that (not tested):
>         >> with VectorTopo('myvector', mode='w') as vectormap:
>         >>     for feature in vectormap:
>         >>         feature.attrs['mycolumn'] = value
>         > Thanks, but that seems to write the vector back without
>         attribute table
>         You have to save the changes in the database out from your
>         cycle, with:
>         vectormap.table.conn.commit()
>     Thanks Pietro. I am, however, not sure I understand (I tried to
>     use it, but thanks to my limited experience in Python / pygrass
>     not much luck). Just to be more specific, I am trying to create a
>     script that divides points in training and test groups, similar to
>     v.kcv, but with points clustered in space. E.g.,
>     # Create vector
>     grass.run_command("v.random", output="testB", npoints=10,
>     overwrite=True)
>     grass.run_command("v.db.addtable", map="testB", columns="X DOUBLE
>     PRECISION,Y DOUBLE PRECISION,GR INTEGER")
>     grass.run_command("v.to.db", map="test", option="coor", columns="X,Y")
>     # Create groups
>     vectmap = 'test'
>     cvals = array(grass.vector_db_select(vectmap, layer = int(1),
>     columns = 'X,Y')['values'].values()).astype(np.float)
>     centroids,_ = kmeans(cvals,2)
>     idx,_ = vq(cvals,centroids)
>     # write results to tabel
>     Now I would like to write idx to the column 'GR' in the attribute
>     table of 'test'.
>     p.s. I am first creating the XY columns now, but is there a
>     function to get the coordinates (cvals) in pygrass directly?
> I don't fully understand the example,
Thanks for the quick response. I basically have a list with values (idx
in the example above) which I like to add as a column to the attribute
table of an existing vector (point layer). The length of idx is equal to
the number of rows in the attribute table. The solution of Anna seems
like an elegant solution (and easier and more flexible than other
solutions I tried using e.g., sqlite3). However, as I wrote, I end up
with a vector without attribute table. You wrote that I "have to save
the changes in the database out from your cycle, with:
vectormap.table.conn.commit()". I am, however, not sure what you mean
with 'out from your cycle' or how to implement that.
> but yes, you can get coordinates:
>         print feature.x
>       print feature.y
Great, thanks. I did not find this in the manual. If it is not there,
perhaps it would be something worth including? I would not mind
providing a text, but I am not sure what would be the best way to do that.
>         Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150930/566f7ff6/attachment.html>
