[GRASS-dev] Write array to (point) attribute table
Anna Petrášová
kratochanna at gmail.com
Wed Sep 30 08:47:21 PDT 2015
On Wed, Sep 30, 2015 at 11:20 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> On 30-09-15 16:18, Anna Petrášová wrote:
> On Wed, Sep 30, 2015 at 9:27 AM, Paulo van Breugel <
> <p.vanbreugel at gmail.com>p.vanbreugel at gmail.com> wrote:
>> On Wed, Sep 30, 2015 at 11:53 AM, Pietro < <peter.zamb at gmail.com>
>> peter.zamb at gmail.com> wrote:
>>> On Wed, Sep 30, 2015 at 9:51 AM, Paulo van Breugel
>>> <p.vanbreugel at gmail.com> wrote:
>>> > On Wed, Sep 30, 2015 at 2:02 AM, Anna Petrášová <kratochanna at gmail.com
>>> > wrote:
>>> >> On Tue, Sep 29, 2015 at 6:09 PM, Paulo van Breugel
>>> >>> This must be a very basic question, but I can't find an easy/direct
>>> way
>>> >>> to do this. In python, if I have an array with values with a length
>>> equal to
>>> >>> the number of rows in an attribute table of a (point) vector layer,
>>> how can
>>> >>> I write those values to a new column in that attribute table. I can
>>> of
>>> >>> course first create the column, but than how to update that column
>>> with the
>>> >>> values in the array?
>>> >> it should be pretty easy to do with pygrass, unfortunately there is no
>>> >> example on assigning attributes in the official documentation [1],
>>> but it
>>> >> should be pretty easy, something like that (not tested):
>>> >> with VectorTopo('myvector', mode='w') as vectormap:
>>> >> for feature in vectormap:
>>> >> feature.attrs['mycolumn'] = value
>>> > Thanks, but that seems to write the vector back without attribute table
>>> You have to save the changes in the database out from your cycle, with:
>>> vectormap.table.conn.commit()
>> Thanks Pietro. I am, however, not sure I understand (I tried to use it,
>> but thanks to my limited experience in Python / pygrass not much luck).
>> Just to be more specific, I am trying to create a script that divides
>> points in training and test groups, similar to v.kcv, but with points
>> clustered in space. E.g.,
>> # Create vector
>> grass.run_command("v.random", output="testB", npoints=10, overwrite=True)
>> grass.run_command("v.db.addtable", map="testB", columns="X DOUBLE
>> PRECISION,Y DOUBLE PRECISION,GR INTEGER")
>> grass.run_command("v.to.db", map="test", option="coor", columns="X,Y")
>> # Create groups
>> vectmap = 'test'
>> cvals = array(grass.vector_db_select(vectmap, layer = int(1), columns =
>> 'X,Y')['values'].values()).astype(np.float)
>> centroids,_ = kmeans(cvals,2)
>> idx,_ = vq(cvals,centroids)
>> # write results to tabel
>> Now I would like to write idx to the column 'GR' in the attribute table
>> of 'test'.
>> p.s. I am first creating the XY columns now, but is there a function to
>> get the coordinates (cvals) in pygrass directly?
>> I don't fully understand the example,
> Thanks for the quick response. I basically have a list with values (idx in
> the example above) which I like to add as a column to the attribute table
> of an existing vector (point layer). The length of idx is equal to the
> number of rows in the attribute table. The solution of Anna seems like an
> elegant solution (and easier and more flexible than other solutions I tried
> using e.g., sqlite3). However, as I wrote, I end up with a vector without
> attribute table. You wrote that I "have to save the changes in the database
> out from your cycle, with: vectormap.table.conn.commit()". I am, however,
> not sure what you mean with 'out from your cycle' or how to implement that.
probably after the for cycle ends you would call this
'vectormap.table.conn.commit()', if it doesn't works, try to put it in the
cycle (I am not sure what is supposed to work).
> but yes, you can get coordinates:
> print feature.x
> print feature.y
> Great, thanks. I did not find this in the manual. If it is not there,
> perhaps it would be something worth including? I would not mind providing a
> text, but I am not sure what would be the best way to do that.
Technically, it's in the manual:
https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html#geometry-classes
but we are lacking more examples of often used constructions. Some other
examples are available in the recent workshop we did:
https://github.com/wenzeslaus/python-grass-addon/blob/master/02_pygrass_library.ipynb
>>> Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150930/8f6a3355/attachment-0001.html>
