[GRASS-dev] [GRASS-user] data catalog question
Anna Petrášová kratochanna at gmail.com
Wed Apr 13 06:27:56 PDT 2016
On Wed, Apr 13, 2016 at 2:43 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> On 13-04-16 05:24, Anna Petrášová wrote:
> On Tue, Apr 12, 2016 at 2:29 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> On Tue, Apr 12, 2016 at 2:21 PM, Paulo van Breugel
> On 12-04-16 18:21, Anna Petrášová wrote:
> On Tue, Apr 12, 2016 at 10:52 AM, Paulo van Breugel
> Hi Anna
> I just updated GRASS trunk version (GRASS GIS 7.1.svn r68252) to test the
> data catalogue. However, when opening the data tab in the main GUI, after
> some waiting, the GUI crashes with:
> GRASS_INFO_ERROR(30614,1): Mapset <backup> does not exist
> this error comes from g.list mapset=backup ...
> and 'backup' comes from running 'g.mapsets -l' for each location.
> Could you run it in the problematic location? Do you get then
> 'backup'? Also you can try to switch on debug mode.
> Found the problem. In one of the locations I had a copy of a mapset folder
> 'Dispersal' which I named 'Dispersal backup', so it is the space in the name
> of the second one that caused the problem.
> I'll try to reproduce it and see if it can be handle this situation better
> I don't know what the rest of the errors mean. If you find the
> problem, I can try to reproduce it.
> Anna
> Weird, I created a mapset with space in the name and everything works...
> When I have a mapset with space, e.g., 'Dispersal backup', and I open for
> the first time the data tab in the main GUI, grass tries to look for a
> mapset 'Dispersal' and a mapset 'backup' (underlined below). Note that there
> also was a real mapset 'Dispersal', not sure if that makes a difference.
> D1/5: grass.script.core.start_command(): g.list --q -mt
> type=raster,raster_3d,vector
> mapset=ConsStat,Dispersal,Dispersal,backup,EthiopiaJvdS,GeneticDistance,JvdS,LUCC,PERMANENT,climchange,samplesize
I fixed that, now it will list the maps in the mapsets correctly.
> On 10-04-16 05:00, Anna Petrášová wrote:
> Hi,
> I was wondering what is the opinion about the new data catalog (in
> trunk), specifically, whether users should be able to modify (copy,
> rename, delete) maps from other mapsets and locations than the current
> ones.
> So now I could try out the new functionality. I can display or copy maps
> from other mapsets, but only if in the same location. If I am in another
> location, there is still the option to display or copy in the context menu
> (right click), but when selecting copy, there is the error message that
> "failed to copy: action is allowed only within the same mapset". When
> selecting 'display', the message is "failed to display:  not in current
> mapset or invalid layer".
> sorry, I still haven't committed it yet, I haven't added the option to
> change it from settings yet, I'll try to add it later today...
> I committed the changes, please test...
> When unlocking (clicking the lock), there is not context menu anymore at
> right click. From the command line:
Fixed, thanks
> GRASS 7.1.svn (nc_spm_08_grass7):~ > Traceback (most recent call last):
>   File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/gui_core/treeview.py",
> line 58, in <lambda>
>     self._emitSignal(evt.GetItem(), self.contextMenu))
> line 161, in _emitSignal
>     signal.emit(node=node, **kwargs)
>   File
> "/usr/local/grass7/grass-7.1.svn/etc/python/grass/pydispatch/signal.py",
> line 229, in emit
>     dispatcher.send(signal=self, *args, **kwargs)
>   File
> "/usr/local/grass7/grass-7.1.svn/etc/python/grass/pydispatch/dispatcher.py",
> line 349, in send
>     **named
>   File
> "/usr/local/grass7/grass-7.1.svn/etc/python/grass/pydispatch/robustapply.py",
> line 60, in robustApply
>     return receiver(*arguments, **named)
>   File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/datacatalog/tree.py",
> line 363, in OnRightClick
>     self._popupMenuLayer()
> line 725, in _popupMenuLayer
>     self.selected_location.label == genv['LOCATION_NAME']:
> UnboundLocalError: local variable 'genv' referenced before assignment
> Anna
> I find it very useful to edit any mapsets, but it goes against
> the traditional GRASS approach. I have this (edit anything behavior)
> implemented locally, but wanted to know before committing if people
> agree with that.
> Thanks,
> Anna
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
