[GRASS-dev] Projection name lookup table needed?
Markus Neteler
neteler at osgeo.org
Thu Apr 14 07:54:38 PDT 2016
I have generated a new location from the EU DEM 25m which comes with
these metadata:
gdalinfo eudem_dem_3035_europe.tif
Driver: GTiff/GeoTIFF
Files: eudem_dem_3035_europe.tif
eudem_dem_3035_europe.tif.ovr
Size is 240000, 200000
Coordinate System is:
PROJCS["ETRS89 / LAEA Europe",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4258"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","3035"]]
Origin = (2000000.000000000000000,6000000.000000000000000)
Pixel Size = (25.000000000000000,-25.000000000000000)
I have then imported the file, cut out a portion with r.mapcalc and
packed up the result with r.pack since I have to deliver the data to
another GRASS user.
For a test, I created a new location with
grass70 -c epsg:3035 ~/grassdata/eu_laea_extra
and tried to import it again. Surprisingly, different spelling created an issue:
r.unpack subregion_eudem_25m.pack
WARNING: Difference between PROJ_INFO file of packed map and of current
- name: ETRS89 / LAEA Europe
+ name: ETRS89 / ETRS-LAEA
datum: etrs89
ellps: grs80
proj: laea
lat_0: 52
lon_0: 10
x_0: 4321000
y_0: 3210000
- towgs84: 0,0,0,0,0,0,0
no_defs: defined
ERROR: Projection of dataset does not appear to match current location. In
case of no significant differences in the projection definitions,
use the -o flag to ignore them and use current location definition.
Question:
in lib/proj/convert.c we have a function papszDatumEquiv(). Do we also
need a similar function for names?
thanks,
Markus
PS: If it matters, here the GDAL version (a Linux Mint box):
gdalinfo --version
GDAL 1.10.1, released 2013/08/26
