[GRASS-dev] Projection name lookup table needed?
Veronica Andreo
veroandreo at gmail.com
Thu Apr 14 12:47:55 PDT 2016
Hi Markus, list
Maybe (un)related.
>From a lat-long location, I'm trying to import TOPO-WMS from mundialis (je!
I like the colors very much! :)) and so, I saved my region of interest
(my_region) and run:
GRASS 7.1.svn (latlong_wgs84):~ > r.in.wms url=
http://ows.mundialis.de/services/service? output=mundialis_topo
layers=TOPO-WMS styles=default srs=4326 region=my_region format=png
Downloading data from WMS server...
Importing raster map into GRASS...
ERROR: Projection of dataset does not appear to match current location.
Location PROJ_INFO is:
proj: ll
datum: wgs84
ellps: wgs84
no_defs: defined
towgs84: 0.000,0.000,0.000
Import dataset PROJ_INFO is:
cellhd.proj = 0 (unreferenced/unknown)
In case of no significant differences in the projection definitions,
use the -o flag to ignore them and use current location definition.
Consider generating a new location from the input dataset using the
'location' parameter.
ERROR: r.in.gdal failed
but i get ERROR, even though EPSG:4326 is listed as available for the layer.
http://ows.mundialis.de/services/service? -c
<Layer queryable="1">
<Name>TOPO-WMS</Name>
<Title>Topographic WMS - by mundialis</Title>
<LatLonBoundingBox minx="-180" miny="-89.999999" maxx="180"
maxy="89.999999" />
<BoundingBox SRS="EPSG:4326" minx="-180" miny="-90" maxx="180"
maxy="90" />
Also from the GUI I get the same error regarding projection (see
screenshot). Maybe I'm doing it completely wrong, dunno... help is welcome
Testing examples from the manual page, I get the same error:
r.in.wms output=kn url=http://wms.cuzk.cz/wms.asp
layers=prehledka_kraju-linie srs=4326 format=png
proj: ll
datum: wgs84
ellps: wgs84
no_defs: defined
My box is Fedora 23 and I'm using:
version=7.1.svn
revision=r68259
build_date=2016-04-14
build_platform=x86_64-pc-linux-gnu
proj4=4.9.1
gdal=2.0.2
geos=3.4.2
sqlite=3.11.0
Cheers,
Vero
2016-04-14 11:54 GMT-03:00 Markus Neteler <neteler at osgeo.org>:
> Hi,
> I have generated a new location from the EU DEM 25m which comes with
> these metadata:
> gdalinfo eudem_dem_3035_europe.tif
> Driver: GTiff/GeoTIFF
> Files: eudem_dem_3035_europe.tif
> eudem_dem_3035_europe.tif.ovr
> Size is 240000, 200000
> Coordinate System is:
> PROJCS["ETRS89 / LAEA Europe",
> GEOGCS["ETRS89",
> DATUM["European_Terrestrial_Reference_System_1989",
> SPHEROID["GRS 1980",6378137,298.2572221010002,
> AUTHORITY["EPSG","7019"]],
> AUTHORITY["EPSG","6258"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4258"]],
> PROJECTION["Lambert_Azimuthal_Equal_Area"],
> PARAMETER["latitude_of_center",52],
> PARAMETER["longitude_of_center",10],
> PARAMETER["false_easting",4321000],
> PARAMETER["false_northing",3210000],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","3035"]]
> Origin = (2000000.000000000000000,6000000.000000000000000)
> Pixel Size = (25.000000000000000,-25.000000000000000)
> I have then imported the file, cut out a portion with r.mapcalc and
> packed up the result with r.pack since I have to deliver the data to
> another GRASS user.
> For a test, I created a new location with
> grass70 -c epsg:3035 ~/grassdata/eu_laea_extra
> and tried to import it again. Surprisingly, different spelling created an
> issue:
> r.unpack subregion_eudem_25m.pack
> WARNING: Difference between PROJ_INFO file of packed map and of current
> location:
> - name: ETRS89 / LAEA Europe
> + name: ETRS89 / ETRS-LAEA
> datum: etrs89
> ellps: grs80
> proj: laea
> lat_0: 52
> lon_0: 10
> x_0: 4321000
> y_0: 3210000
> - towgs84: 0,0,0,0,0,0,0
> no_defs: defined
> ERROR: Projection of dataset does not appear to match current location. In
> Question:
> in lib/proj/convert.c we have a function papszDatumEquiv(). Do we also
> need a similar function for names?
> thanks,
> Markus
> PS: If it matters, here the GDAL version (a Linux Mint box):
> gdalinfo --version
> GDAL 1.10.1, released 2013/08/26
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160414/24be3c30/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160414/24be3c30/attachment-0001.png>
