[GRASS-dev] [GRASS GIS] #2986: r.mapcalc with same variable on LHS and RHS
trac at osgeo.org
Thu Apr 21 06:04:29 PDT 2016
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 7.0.4
Component: Docs | Version: 7.0.3
Resolution: fixed | Keywords: r.mapcalc
CPU: Unspecified | Platform: Unspecified
Comment (by glynn):
Replying to [comment:6 glynn]:
> Replying to [comment:5 mankoff]:
> > Just to be clear, {{{LHS = RHS}}} **does** work.
Something else which doesn't quite work as expected is that once a name
appears on the LHS of an assignment, it's marked as being a variable
rather than a map. Which means that you can't use any modifiers on it
(whether the neighbourhood modifier, the category modifier or any colour
channel modifiers), as those can only be used on maps, not variables.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2986#comment:7>
