[GRASS-dev] [GRASS GIS] #2986: r.mapcalc with same variable on LHS and RHS
trac at osgeo.org
Thu Apr 21 06:29:08 PDT 2016
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 7.0.4
Component: Docs | Version: 7.0.3
Resolution: fixed | Keywords: r.mapcalc
CPU: Unspecified | Platform: Unspecified
Comment (by mankoff):
I'm still confused. The specific case of {{{r.mapcalc 'map=map'}}}
mentioned 2 comments above does seem to work for me in v7.0.3 (see code
example below). Also, the last comment appears to say that everything on
the LHS, even if a new unique LHSname, will be a variable and not a map
(I'm not even sure what "variables" are in GRASS). But the documentation
says that, //"result is the name of a raster map layer"//, and I thought
the whole point of {{{r.mapcalc}}} was to produce new raster maps.
Finally, there is no evidence, at least from {{{r.info}}}, of results
changing type. See for example results from,
grass70 -text ./nc_spm_08_grass7/PERMANENT
r.mapcalc "LHS = 1" --o
r.info LHS > rinfo.1
r.mapcalc "LHS = LHS" --o
r.info LHS > rinfo.2
r.mapcalc "LHS = LHS * 2" --o
r.info LHS > rinfo.3
diff3 rinfo.1 rinfo.2 rinfo.3
Finally, would it be possible to change this behavior, so that
{{{r.mapcalc 'map = map * 2'}}} is valid syntax? It seems like it would be
incredibly useful to support this standard programming syntax. If it isn't
a major code issue, I'll open a ticket with this feature request.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2986#comment:8>
