[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
trac at osgeo.org
Sun Apr 24 10:07:52 PDT 2016
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.1.0
Component: Projections/Datums | Version: svn-releasebranch70
Resolution: | Keywords: gdal
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Also EPSG 3358 (NC) is an issue:
grass71 -c epsg:3358 ~/grassdata/nc_data
GRASS 7.1.svn (nc_data):~ > g.proj -w
PROJCS["NAD83(HARN) / North Carolina",
GEOGCS["grs80",
DATUM["unknown",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",36.16666666666666],
PARAMETER["standard_parallel_2",34.33333333333334],
PARAMETER["latitude_of_origin",33.75],
PARAMETER["central_meridian",-79],
PARAMETER["false_easting",609601.22],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Expected: http://epsg.io/3358 :
GEOGCS["NAD83(HARN)",
DATUM["NAD83_High_Accuracy_Reference_Network",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6152"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4152"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["X",EAST],
AXIS["Y",NORTH],
AUTHORITY["EPSG","3358"]]
The recognition of datum name "NAD83_High_Accuracy_Reference_Network"
fails.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2456#comment:16>
