[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Apr 25 13:02:20 PDT 2016
Hi Markus, Even,
On 04/24/2016 10:29 PM, Markus Neteler wrote:
> Hi Paul,
> you are probably the person with most insights into lib/proj/convert.c.
> I try to debug why the North Carolina Location cannot be generated
> properly (EPSG 3358) but comes out like this:
> grass71 -c epsg:3358 ~/grassdata/nc_data
> GRASS 7.1.svn (nc_data):~ > g.proj -w
> PROJCS["NAD83(HARN) / North Carolina",
> GEOGCS["grs80",
> DATUM["unknown",
The datum name "unknown" is coming through from GDAL. Here is a simple
test program to illustrate it (using latest SVN GDAL from this evening):
#include <stdio.h>
#include <ogr_srs_api.h>
main()
OGRSpatialReferenceH hSRS;
const char *datum;
hSRS = OSRNewSpatialReference(NULL);
OSRImportFromProj4(hSRS, "+init=epsg:3358");
datum = OSRGetAttrValue(hSRS, "DATUM", 0);
printf("Datum name is %s\n", datum);
return 0;
Compile as:
gcc -Wall -o test test.c -lgdal
and run:
./test
Datum name is unknown
Perhaps there is a better / more correct way to get the co-ordinate
system definition from GDAL than by requesting it as a "+init=epsg:XXXX"
PROJ string?
Paul
