[GRASS-dev] r.volume - error: reading raster at row x outside of region
Helmut Kudrnovsky hellik at web.de
Sun Apr 24 13:06:28 PDT 2016
Helmut Kudrnovsky wrote
> Hi devs,
> I have 2 rasters:
> r.info map=sample_tallard_eu_dem_westernalps_slope
>  | Map:      sample_tallard_eu_dem_western  Date: Sun Apr 24 20:36:43 2016
>  | Mapset:   westernalpsriver               Login of Creator: bugs
>  | Location: eudem_epsg3035
>  | DataBase: /home/bugs/grassdata
>  | Title:    slope in degrees ( sample_tallard_eu_dem_westernalps_slope )
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 77
>  |   Data Type:    FCELL
>  |   Rows:         4713
>  |   Columns:      4808
>  |   Total Cells:  22660104
>  |        Projection: Lambert Azimuthal Equal Area
>  |            N:    2460525    S:    2342700   Res:    25
>  |            E:    4098800    W:    3978600   Res:    25
>  |   Range of data:    min = 0  max = 76.56607
>  |   Data Source:
>  |    raster elevation file r_elevation_crop
>  |   Data Description:
>  |    generated by r.slope.aspect
>  |   Comments:
>  |    slope map elev = r_elevation_crop
>  |    zfactor = 1.00 format = degrees
>  |    min_slope = 0.000000
>  |    r.slope.aspect elevation="r_elevation_crop"
> slope="sample_tallard_eu\   |
>  |    _dem_westernalps_slope"
> aspect="sample_tallard_eu_dem_westernalps_as\   |
>  |    pect" format="degrees" precision="FCELL" zscale=1.0 min_slope=0.0
>  r.info map=sample_tallard_eu_dem_westernalps_basin
>  | Map:      sample_tallard_eu_dem_western  Date: Sun Apr 24 20:36:03 2016
>  | Title:     ( sample_tallard_eu_dem_westernalps_basin )
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 0
>  |   Data Type:    CELL
>  |   Rows:         4713
>  |   Columns:      4808
>  |   Range of data:    min = 1  max = 1
>  |   Data Description:
>  |    generated by r.stream.basins
>  |   Comments:
>  |    r.stream.basins
> direction="sample_tallard_eu_dem_westernalps_drainag\   |
>  |    e_e" points="sample_tallard_eu_dem_westernalps_outlet_snap"
> memory=3\   |
>  |    00 basins="sample_tallard_eu_dem_westernalps_basin"
> when I do r.volume with these rasters, I get:
> r.volume --verbose input=sample_tallard_eu_dem_westernalps_slope
> clump=sample_tallard_eu_dem_westernalps_basin
> ERROR: Die Leseanfrage der Rasterkarte
> <sample_tallard_eu_dem_westernalps_basin@> für Zeile -82 ist
> außerhalb der Region.
> ERROR: Reading of raster map
> <sample_tallard_eu_dem_westernalps_basin@> for row -82 is outside
> the region.
> D3/3: row=4712 col=4805: zero or negs ignored
> D3/3: row=4712 col=4806: zero or negs ignored
> D3/3: row=4712 col=4807: zero or negs ignored
>  100%
> FEHLER: Die Leseanfrage der Rasterkarte
> the computational region:
> g.region -p -a raster=eu_dem_westernalps at westernalpsriver
> vector=v_region_durance_buffer5000 at westernalpsriver
> align=eu_dem_westernalps at westernalpsriver
> projection: 99 (Lambert Azimuthal Equal Area)
> zone:       0
> datum:      etrs89
> ellipsoid:  grs80
> north:      2460525
> south:      2342700
> west:       3978600
> east:       4098800
> nsres:      25
> ewres:      25
> rows:       4713
> cols:       4808
> cells:      22660104
> any idea what causes such an error?
> r.volume, tested with a lot of other rasters of different extents, worked
> so far ...
Maybe some memory issue?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-volume-error-reading-raster-at-row-x-outside-of-region-tp5262679p5262683.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
