[GRASS-dev] projection NC sample data set
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Apr 28 00:56:04 PDT 2016
On Tue, Apr 26, 2016 at 7:23 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> On Wed, Apr 20, 2016 at 11:02 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
> > Hi, on https://grass.osgeo.org/download/sample-data/ it is suggested
> that
> > the projection of the NC sample data set is NAD83(HARN) / North Carolina
> > EPSG 3358).
> Some libproj parts got fixed in the last 24hs, please try again. It
> now looks like this:
> grass70 -c epsg:3358 ~/grassdata/nc_data
> Cleaning up temporary files...
> Creating new GRASS GIS location/mapset...
> GRASS 7.0.4svn (nc_data):~/mundialis/ideas > g.proj -w
> PROJCS["NAD83(HARN) / North Carolina",
> GEOGCS["grs80",
> DATUM["NAD83_High_Accuracy_Reference_Network",
> SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> PARAMETER["standard_parallel_1",36.16666666666666],
> PARAMETER["standard_parallel_2",34.33333333333334],
> PARAMETER["latitude_of_origin",33.75],
> PARAMETER["central_meridian",-79],
> PARAMETER["false_easting",609601.22],
> PARAMETER["false_northing",0],
> UNIT["Meter",1]]
> which should be right.
Great, thanks, also to Paul Kelly and Even Roualt
> Best
> Markus
> PS: Kudos to Paul Kelly and Even Rouault for their help (via grass-dev
> and personal emails)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160428/d31d2202/attachment.html>
