[GRASS-dev] projection NC sample data set
Markus Neteler
neteler at osgeo.org
Tue Apr 26 10:23:45 PDT 2016
On Wed, Apr 20, 2016 at 11:02 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi, on https://grass.osgeo.org/download/sample-data/ it is suggested that
> the projection of the NC sample data set is NAD83(HARN) / North Carolina (
> EPSG 3358).
Some libproj parts got fixed in the last 24hs, please try again. It
now looks like this:
grass70 -c epsg:3358 ~/grassdata/nc_data
Cleaning up temporary files...
Creating new GRASS GIS location/mapset...
GRASS 7.0.4svn (nc_data):~/mundialis/ideas > g.proj -w
PROJCS["NAD83(HARN) / North Carolina",
GEOGCS["grs80",
DATUM["NAD83_High_Accuracy_Reference_Network",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",36.16666666666666],
PARAMETER["standard_parallel_2",34.33333333333334],
PARAMETER["latitude_of_origin",33.75],
PARAMETER["central_meridian",-79],
PARAMETER["false_easting",609601.22],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
which should be right.
Best
Markus
PS: Kudos to Paul Kelly and Even Rouault for their help (via grass-dev
and personal emails)
