[GRASS-dev] projection NC sample data set
Markus Neteler
neteler at osgeo.org
Sun Apr 24 10:10:02 PDT 2016
On Wed, Apr 20, 2016 at 11:02 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi, on https://grass.osgeo.org/download/sample-data/ it is suggested that
> the projection of the NC sample data set is NAD83(HARN) / North Carolina (
> EPSG 3358). However, according to the projection information of the sample
> dataset it self, the projection is Lambert Conformal Conic.
http://epsg.io/3358
PROJECTION["Lambert_Conformal_Conic_2SP"],
> The description on http://georepository.com/ reads that NAD83(HARN) / North
> Carolina uses the NAD83(HARN) geographic 2D CRS as its base CRS and the
> SPCS83 North Carolina zone (meters) (Lambert Conic Conformal (2SP)) as its
> projection. So I see where the LCC is coming from.
> If, however, I create a new location with EPSG 3358, the name of the
> projection (g.region -p) is NAD83(HARN) / North Carolina.
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.proj -c epsg=3358 location=nc_test
Location <nc_test> created
You can switch to the new location by
`g.mapset mapset=PERMANENT location=nc_test`
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.mapset mapset=PERMANENT location=nc_test
Mapset switched. Your shell continues to use the history for the old mapset
You can switch the history by commands:
history -w; history -r
/home/neteler/grassdata/nc_test/PERMANENT/.bash_history;
HISTFILE=/home/neteler/grassdata/nc_test/PERMANENT/.bash_history
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.proj -w
PROJCS["NAD83(HARN) / North Carolina",
GEOGCS["grs80",
DATUM["unknown",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PARAMETER["standard_parallel_1",36.16666666666666],
PARAMETER["standard_parallel_2",34.33333333333334],
PARAMETER["latitude_of_origin",33.75],
PARAMETER["central_meridian",-79],
PARAMETER["false_easting",609601.22],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
It appears that GRASS/GDAL does not understand
DATUM["NAD83_High_Accuracy_Reference_Network",
An issue for
https://trac.osgeo.org/grass/ticket/2456
Since we now read this information from GDAL, I'm rather lost why 3358
still fails to be recognized properly?!
Maybe https://trac.osgeo.org/grass/changeset/68131 is yet incomplete?
Markus
