[GRASS-dev] projection NC sample data set
Paulo van Breugel
p.vanbreugel at gmail.com
Wed Apr 20 02:02:20 PDT 2016
Hi, on https://grass.osgeo.org/download/sample-data/ it is suggested that
the projection of the NC sample data set is NAD83(HARN) / North Carolina (
EPSG 3358). However, according to the projection information of the sample
dataset it self, the projection is Lambert Conformal Conic.
The description on http://georepository.com/ reads that NAD83(HARN) / North
Carolina uses the NAD83(HARN) geographic 2D CRS as its base CRS and the
SPCS83 North Carolina zone (meters) (Lambert Conic Conformal (2SP)) as its
projection. So I see where the LCC is coming from.
If, however, I create a new location with EPSG 3358, the name of the
projection (g.region -p) is NAD83(HARN) / North Carolina.
Which of the two should be given / shown with g.region -p I am not sure,
but I think it would be good to be consistent.
Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160420/1bfc9c7d/attachment.html>
