[GRASS-dev] Memory use in v.in.lidar for points with attributes
Newcomb, Doug
doug_newcomb at fws.gov
Wed Aug 3 07:20:00 PDT 2016
v.lidar.mcc seems to be running fine without attributes or topology. Not
sure why I thought it needed a regular point vector layer. Sorry for the
noise.
Doug
On Fri, Jul 22, 2016 at 11:27 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 22/07/16 16:05, Newcomb, Doug wrote:
>> Hi Folks,
>> My goal is to import a LiDAR point cloud from an LAS file with 152
>> million points. I would like to use v.lidar.mcc to extract bare earth
>> points from the point cloud for generating a DEM However, v.lidar.mcc
>> requires that the point layer have an attribute table
> Are you sure ? The example in the v.lidar.mcc man page says:
> v.in.lidar -tr input=points.las output=points
> v.lidar.mcc points ground=ground_points nonground=non_ground_points
> the -t in v.in.lidar means "Do not create attribute table".
> > rather than just
> > the raw x,y,z points without topography.
> Do you mean topology ?
> Attribute table and topology are two seperate issues.
>> So using v.in.lidar, I am importing the lidar points as normal points,
>> and the memory usage is steadily climbing. Less than 1/4 of the points
>> are imported and memory usage is at 5GB . This on a Windows 7 64 bit
>> system with GRASS 7.2 svn
>> I'm suspecting this is not the expected behavior.
> I would say that it is expected. YMMMV with different database backends,
> but attribute handling can be memory-heavy.
> What does v.in.lidar -t give you ?
> If some attribute really need to be conserver, maybe this a good case to
> test Vaclav's additions to v.in.lidar, storing attributes as cat values,
> instead of attributes in a table:
> https://lists.osgeo.org/pipermail/grass-dev/2015-September/076490.html
> https://trac.osgeo.org/grass/changeset/66343
> Moritz
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior. Life is too short for undocumented, proprietary data formats.
As a federal employee, my email may be subject to FOIA request.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160803/7ae017ea/attachment.html>
