[GRASS-dev] m.printws - new module recommendation/announcement
Robert Kuszinger
kuszinger at giscom.hu
Wed Aug 3 23:29:20 PDT 2016
Dear Veronica,
Anna was faster with her answer. To ease the use I'll put it into a
standalone repo as Anna recommended and test myself the g.extension way.
Also I'm happy to hear that now it runs.
Thanks
Robert
2016-08-03 21:47 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
> Thanks much for the instructions, Anna!
> In the end, what I did was to download the whole folder, unzip, extract
> only the m.printws, zip it and use g.extension
> g.extension m.printws url=/home/veroandreo/software/m.printws.zip
> and it worked perfectly :)
> best,
> Vero
> 2016-08-03 16:14 GMT-03:00 Anna Petrášová <kratochanna at gmail.com>:
>> I think it's because it's not at top level in the repository.
>> g.extension expects the module is at top level and creates an URL of
>> the zip. Github doesn't seem to allow you to download a subdirectory
>> from the repo as a zip, so I don't think we can do anything about it,
>> at least not easily.
>> Either download the module manually and run in the directory with the
>> module:
>> make MODULE_TOPDIR=/path/to/trunk
>> make install MODULE_TOPDIR=/path/to/trunk
>> * or Robert can split the repo into two, one for each addon. *
>> Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160804/e2925890/attachment.html>
