[GRASS-dev] m.printws - new module recommendation/announcement
Anna Petrášová
kratochanna at gmail.com
Wed Aug 3 12:14:27 PDT 2016
On Wed, Aug 3, 2016 at 2:49 PM, Veronica Andreo <veroandreo at gmail.com> wrote:
> Hello Robert,
> I would like to test this new add-on very much, but I haven't been able to
> install it with g.extension as explained here:
> https://grass.osgeo.org/grass73/manuals/g.extension.html for the case of
> repositories other than SVN. This is the command I'm using:
> g.extension m.printws
> url=github.com/kuszinger/giscomgrass7addons/tree/master/m.printws
> Fetching <m.printws> from
> <https://github.com/kuszinger/giscomgrass7addons/tree/master/m.printws/archive/master.zip>
> (be patient)...
> ERROR: Extension <m.printws> not found
> (I'm using a freshly recompiled grass73 - r69069M under Linux-Fedora24)
> Am I using g.extension properly? Any ideas?
I think it's because it's not at top level in the repository.
g.extension expects the module is at top level and creates an URL of
the zip. Github doesn't seem to allow you to download a subdirectory
from the repo as a zip, so I don't think we can do anything about it,
at least not easily.
Either download the module manually and run in the directory with the module:
make MODULE_TOPDIR=/path/to/trunk
make install MODULE_TOPDIR=/path/to/trunk
or Robert can split the repo into two, one for each addon.
Anna
> Best,
> Vero
> 2016-08-03 11:15 GMT-03:00 Robert Kuszinger <kuszinger at giscom.hu>:
>> Hi all,
>> I've created a new python script which generates:
>> quick printout (pdf) from workspace definitions
>> supports multiple display definitions in one workspace ( = multiple
>> printouts in one run)
>> UTF-8 text could also be printed (ps.map supports only latin1, this was
>> the initial reason to create alternative print method)
>> known major issues:
>> barscale and northarrow positioning should be revised in the respective
>> d.* modules
>> ImageMagick dependency should be eliminated longer term
>> regexp processing of workspace files instead of formal XML processing
>> needs more calibration on txt/symbol resizing according to printout dpi
>> change
>> This module is NOT for professional prints but for quick&dirty and
>> hopefully comfortable
>> printout making.
>> Tested under:
>> Linux: 7.0.4,7.2 latest, 7.3 weekly snapshot
>> Windows: 7.3 binary OSGeo4W
>> Source and doc are here:
>> best regards
>> Robert
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
