[GRASS-dev] m.printws - new module recommendation/announcement
Veronica Andreo veroandreo at gmail.com
Wed Aug 3 12:47:40 PDT 2016
Thanks much for the instructions, Anna!
In the end, what I did was to download the whole folder, unzip, extract
only the m.printws, zip it and use g.extension
g.extension m.printws url=/home/veroandreo/software/m.printws.zip
and it worked perfectly :)
best,
Vero
2016-08-03 16:14 GMT-03:00 Anna Petrášová <kratochanna at gmail.com>:
> On Wed, Aug 3, 2016 at 2:49 PM, Veronica Andreo <veroandreo at gmail.com>
> wrote:
> > Hello Robert,
> > I would like to test this new add-on very much, but I haven't been able
> to
> > install it with g.extension as explained here:
> > https://grass.osgeo.org/grass73/manuals/g.extension.html for the case of
> > repositories other than SVN. This is the command I'm using:
> > url=github.com/kuszinger/giscomgrass7addons/tree/master/m.printws
> > Fetching <m.printws> from
> https://github.com/kuszinger/giscomgrass7addons/tree/master/m.printws/archive/master.zip
> > (be patient)...
> > ERROR: Extension <m.printws> not found
> > (I'm using a freshly recompiled grass73 - r69069M under Linux-Fedora24)
> > Am I using g.extension properly? Any ideas?
> I think it's because it's not at top level in the repository.
> g.extension expects the module is at top level and creates an URL of
> the zip. Github doesn't seem to allow you to download a subdirectory
> from the repo as a zip, so I don't think we can do anything about it,
> at least not easily.
> Either download the module manually and run in the directory with the
> module:
> make MODULE_TOPDIR=/path/to/trunk
> make install MODULE_TOPDIR=/path/to/trunk
> or Robert can split the repo into two, one for each addon.
> Anna
> > Best,
> > Vero
> > 2016-08-03 11:15 GMT-03:00 Robert Kuszinger <kuszinger at giscom.hu>:
> >> Hi all,
> >> I've created a new python script which generates:
> >> quick printout (pdf) from workspace definitions
> >> supports multiple display definitions in one workspace ( = multiple
> >> printouts in one run)
> >> UTF-8 text could also be printed (ps.map supports only latin1, this was
> >> the initial reason to create alternative print method)
> >> known major issues:
> >> barscale and northarrow positioning should be revised in the respective
> >> d.* modules
> >> ImageMagick dependency should be eliminated longer term
> >> regexp processing of workspace files instead of formal XML processing
> >> needs more calibration on txt/symbol resizing according to printout dpi
> >> change
> >> This module is NOT for professional prints but for quick&dirty and
> >> hopefully comfortable
> >> printout making.
> >> Tested under:
> >> Linux: 7.0.4,7.2 latest, 7.3 weekly snapshot
> >> Windows: 7.3 binary OSGeo4W
> >> Source and doc are here:
> >> best regards
> >> Robert
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160803/cbd9a194/attachment.html>
