[GRASS-dev] [GRASS GIS] #3115: v.kriging: segfault if a parameter is not set
trac at osgeo.org
Thu Aug 4 06:42:31 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Addons | Version: unspecified
Keywords: v.kriging required parameter | CPU: Unspecified
segfault |
Platform: Unspecified |
In the v.kriging addon, when I only provide the parameters marked as
required (+ the -2 flag for 2D interpolation) I get the following:
v.extract elev_lid792_randpts out=elev_lid792_selected random=500 --o
v.kriging -2 input=elev_lid792_selected at user1 phase=initial icolumn=value
WARNING: Not recommended to process for sparse or spatially heterogeneous
data. The result can be inaccurate - trying to solve asap...
Reading coordinates...
Segmentation fault
I have to add the report parameter for it to work:
report=report.txt
At this stage, two unasked-for files are in the same directory: dataE.dat
and
variogram_hz_tmp.txt.
Required parameters should be declared as such and not lead to a segfault.
And any temporary files created during the run of the module should be
erased at the end.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3115>
