[GRASS-dev] [GRASS GIS] #3071: v.db.join: fails with SQLite because of lower/UPPER case issues
trac at osgeo.org
Sun Aug 7 13:27:18 PDT 2016
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
I checked the patches:
* v.db.addcolumn_quote.diff: contains backticks. This is unlikely to
work in Python/SQL. Is this an encoding issue of the patch?
* v.db.join.diff: Not sure how SQLite behaves. I found an older
discussion here: http://stackoverflow.com/a/19933159/452464 - is there
any official reference on the SQLite site?
* v.db.join_quote.diff: If quotes are needed then also the other SQL
queries needs to undergo an audit. Then we need to write down our coding
style somewhere near
https://trac.osgeo.org/grass/wiki/Grass7/VectorLib/OGRInterface or better
a dedicated SQL/DBMI page
Ticket URL: <https://trac.osgeo.org/grass/ticket/3071#comment:2>
