[GRASS-dev] [GRASS GIS] #3071: v.db.join: fails with SQLite because of lower/UPPER case issues
trac at osgeo.org
Sun Aug 7 14:02:19 PDT 2016
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
Replying to [comment:2 neteler]:
> I checked the patches:
> * v.db.addcolumn_quote.diff: contains backticks. This is unlikely to
work in Python/SQL. Is this an encoding issue of the patch?
backticks are used in MySQL to quote identifiers:
http://dev.mysql.com/doc/refman/5.7/en/identifiers.html
> * v.db.join.diff: Not sure how SQLite behaves. I found an older
discussion here: http://stackoverflow.com/a/19933159/452464 - is there
any official reference on the SQLite site?
See: https://www.sqlite.org/lang_keywords.html
> * v.db.join_quote.diff: If quotes are needed then also the other SQL
queries needs to undergo an audit. Then we need to write down our coding
style somewhere near
https://trac.osgeo.org/grass/wiki/Grass7/VectorLib/OGRInterface or better
a dedicated SQL/DBMI page
It is indeed something that probably requires a deliberate decision either
to allow for table and column names that require quoted identifiers in
GRASS modules or not (of course users can do anything the DB backends
allow for outside GRASS or using db.execute).[[BR]]
A drawback of quoted identifiers is that also nonsense - including SQL
keywords - is possible e.g. in column names.[[BR]]
However, v.in.ogr writes data source names (which can contain upper case
characters) as layer names, which again are (at least in some cases) used
as table names. And also column names can be laundered to lower case
during import (or not, users choice), making it hard to foresee if quoting
is required, esp. in multi user environments.[[BR]]
So, at the moment at least, users can run into UPPER/lower case issues for
different reasons.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3071#comment:3>
