[GRASS-dev] Rendering of vector layers can be slow
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon Aug 8 02:27:15 PDT 2016
At the moment I am fixing and quality checking relatively larger vector datasets with some 100k areas, of which some are quite complex (sea area / coast line). That requires visual inspection of the data and thus repeated rendering at different scales.
In this context I am struggling with rendering speed in GRASS 7.0.4. I am working on a relatively powerful server with local data in native GRASS format.
In comparison, QGIS on my local laptop renders the same data from PostGIS significantly faster, even when fetched through a WLAN connection...
Any possibilities to speed up rendering of vector maps?
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160808/c8037401/attachment.html>
