[GRASS-dev] Rendering of vector layers can be slow
Moritz Lennert
mlennert at club.worldonline.be
Tue Aug 9 00:37:42 PDT 2016
On 08/08/16 11:27, Blumentrath, Stefan wrote:
> Hi,
> At the moment I am fixing and quality checking relatively larger vector
> datasets with some 100k areas, of which some are quite complex (sea area
> / coast line). That requires visual inspection of the data and thus
> repeated rendering at different scales.
> In this context I am struggling with rendering speed in GRASS 7.0.4. I
> am working on a relatively powerful server with local data in native
> GRASS format.
Vector rendering speed has been an issue and has been discussed before,
a long time ago [1, 2], but I don't remember if there was much follow-up
in terms of changing d.vect. The issue was mentioned again later [3].
Also see the debate in [4], but this was not explicitely about vector
rendering.
> In comparison, QGIS on my local laptop renders the same data from
> PostGIS significantly faster, even when fetched through a WLAN connection...
AFAIK, QGIS now has multithreaded rendering. I don't know if this
creates the difference. Also watch out: QGIS starts rendering parts of
the layer very quickly, but you have to compare the time it takes for
both to render the entire layer.
> Any possibilities to speed up rendering of vector maps?
Maybe some of the ideas Glynn advanced in the response to [2] are still
relevant. I don't think there have been any changes related to these
ideas to lib/gis/plot.c since that discussion.
I agree that this would probably be of use, but I guess it never has
been an itch strong enough to provoke those who have the knowledge into
action. :-)
Moritz
[1] https://lists.osgeo.org/pipermail/grass-dev/2006-August/025250.html
[2] https://lists.osgeo.org/pipermail/grass-dev/2006-September/025858.html
[3] https://lists.osgeo.org/pipermail/grass-dev/2012-August/059178.html
[4] https://trac.osgeo.org/grass/ticket/2033
