[GRASS-dev] [GRASS GIS] #3122: d.legend.vect: possibility to change text of displayed labels and select labels to show/not show
GRASS GIS trac at osgeo.org
Mon Aug 8 15:25:09 PDT 2016
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:              |     Status:  new
  enhancement            |
  Priority:  normal      |  Milestone:  7.3.0
 Component:  Display     |    Version:  unspecified
Resolution:              |   Keywords:  d.legend.vect, gsoc2016,
       CPU:              |  cartography
  Unspecified            |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:3 veroandreo]:
 > Replying to [comment:2 mlennert]:
 > > Replying to [comment:1 annakrat]:
 > > > Replying to [ticket:3122 veroandreo]:
 > > > > Hello,
 > > > > I've been testing the new d.legend.vect and it is great :)
 > > > > However, I found that it would be even better if one could change
 the label displayed. Not always the name of the vector map is the best
 option, especially if one is displaying for example only one category of
 an attribute. For instance, I have presence/absence points and only want
 to display presence points. I'd like to be able to tweak the label to be
 "presence" instead of the name of the vector map.
 > > > This is already possible using d.vect parameter legend_label.
 > Oh, I missed that one
 > > Yes, but this does not seem to like spaces. If I use a label such as
 "Areas < 10e6" it only displays "Areas". Same with "Large Areas", I only
 get "Large" in the display. It does not make any difference if I enclose
 the text in quotes, or not.
 > Same here :(
 > Don't know how difficult it might be, but maybe it would be easier (and
 more visible, probably) from a user point of view, if that "legend_label"
 parameter would be integrated in d.legend.vect, instead of having to set
 the label in d.vect to then have it displayed with d.legend.vect
 I prefer to have it in d.vect as that is where the layer is defined. In
 d.legend.vect, this would be awkward as a d.legend.vect call could concern
 anything from 1-X layers and so potentially you would need X text fields
 to define labels and X is not defined beforehand. So, I would plead to
 keep it as is, but just to improve the handling of special characters,
 including spaces, in the text.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3122#comment:4>
