[GRASS-dev] [GRASS GIS] #3122: d.legend.vect: possibility to change text of displayed labels and select labels to show/not show
trac at osgeo.org
Mon Aug 8 10:09:37 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 7.3.0
Component: Display | Version: unspecified
Resolution: | Keywords: d.legend.vect, gsoc2016,
CPU: | cartography
Unspecified | Platform: Unspecified
Comment (by veroandreo):
Replying to [comment:2 mlennert]:
> Replying to [comment:1 annakrat]:
> > Replying to [ticket:3122 veroandreo]:
> > > Hello,
> > > I've been testing the new d.legend.vect and it is great :)
> > > However, I found that it would be even better if one could change
the label displayed. Not always the name of the vector map is the best
option, especially if one is displaying for example only one category of
an attribute. For instance, I have presence/absence points and only want
to display presence points. I'd like to be able to tweak the label to be
"presence" instead of the name of the vector map.
> > This is already possible using d.vect parameter legend_label.
Oh, I missed that one
> Yes, but this does not seem to like spaces. If I use a label such as
"Areas < 10e6" it only displays "Areas". Same with "Large Areas", I only
get "Large" in the display. It does not make any difference if I enclose
the text in quotes, or not.
Same here :(
Don't know how difficult it might be, but maybe it would be easier (and
more visible, probably) from a user point of view, if that "legend_label"
parameter would be integrated in d.legend.vect, instead of having to set
the label in d.vect to then have it displayed with d.legend.vect
Ticket URL: <https://trac.osgeo.org/grass/ticket/3122#comment:3>
